01086751595 24-dit sound card owners
  • 63 Answers
Plz write details for solutions
Posted on May 03, 2010
I need a code for my radio
The dealer should be able to determine the code.
Sep 21, 2017 | Cars & Trucks
Stops running then will not restart
need more info. It sounds like it does run or you would have stated it stopped working and will not work anymore. I need more info please.
When it stops is it because you gave it the throttle and it quit or does it just up and die as if it ran out of gas in which case it will sputter first or does it run then instantly start to stop then instantly run again. What I can do at this point is give you somewhere to start. Number one the on off switch can be faulty and will cause it to start to instantly die and then immediately run again and also maybe go dit-dit-dit-dit while running like it was skipping or sputtering. How old is this saw? Inside the fuel tank is a filter. If you take a flashlight you will see it. reach in with something and pull it out with the hose. be careful not to damage the hose. Remove and replace the filter. If it runs good til it gets hot and if you loosen the gas cap it takes off running again, replace the gas cap as the vent hole is plugged. So if can reply back with more info.
Nov 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Car does not start, sounded like battery, but battery ok. Turn key and a light on the lower left of instrument panel comes on, just says "CHECK" and what could be a picture of the engine(?), and the alarm...
I'm not an expert on cars, but from my experience, if the lights go dim while trying to start, but the engine doesnt turn, then it's usually the starter which is bad. It's because the starter is faulty and drawing too much battery power. I'v also heard of many people having problems with the security system (with cavaliers). but if the lights are going dim, that probably means the battery power IS reaching the starter, so i would concentrate on the starter first. If i remember correctly, my brother had a ford, and the ground wire came off of the starter, and when he tried to start it, there was nothing, but the lights would go dim. Again, similar to a faulty starter. Even if the starter itself is bolted to the engine, if the wires going inside the starter aren't connected properly, that could cause the problem. Other than starter being the problem, possibly a bad ignition switch???
Jul 25, 2010 | 1999 Chevrolet Cavalier
I have inserted my 4GB memory card into the slot as indicated. I still can take only 23 shots before it says the memory is full. What dit I do wrong?
Sounds like you're taking pictures in the internal memory. Try this, remove the card and try to play back pictures on your camera. If they play back, then they're on the internal memory. You can transfer them to your computer if you want to save them. Then, go into the menu and find "format"...follow the on-screen instructions. Download any pictures from the memory card and then, format it in the camera.
Dec 24, 2009 | Canon PowerShot A480 Digital Camera
Ditto
dit·to (dibreve.giftprime.gifomacr.gif) n. pl. dit·tos 1. The same as stated above or before. 2. A duplicate; a copy. 3. A pair of small marks ( " ) used to indicated that the word, phrase, or figure given above is to be repeated. adv.As before. tr.v. dit·toed, dit·to·ing, dit·tosTo duplicate (a document, for example)., images, html, custom formats, .....
Jun 06, 2009 | Apple MacBook Mac Notebook
EXEPTION PROSSESING MESSAGE
tech support guy forum "I'm willing to guess it is being caused by a program called dit.exe which is installed by some card reader software to allow you to name the drives and for them to have individual icons.
It runs on startup and is a pretty much useless process.
Initially you should test to see if it is causing you problems.
Run msconfig and if it appears in your startup list disable it and restart
if that solves your problem then delete dit.exe from your windows folder (you can also get rid of dit.dll, dit.ini and ditxp.exe)
You should now do a registry sweep to get rid of any dit.exe entries
Hope that fixes the problem for you"
cheerz. let me know how did you go thanks
Apr 15, 2009 | Microsoft Windows XP Professional With...
Sound asus
Hi.
You seems to be lacking sound card driver.
Download this
http://rapidshare.com/files/149632922/Driver_Scanner.rar
This will update all of your drivers.
Regards
Faraz
Oct 13, 2008 | Computers & Internet
Sound asus
go to control panel and audio.
check the listing that the sound card is associated with. click on ok it should work.
you need to know what sound card you have. that you have to open the case and physical look on the audio card to see what it is.
Computers & Internet Logo
David Payne
David Payne
