Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer evaporator is not cooling all way ap to the top only 2 turns of botton coil
  • 2,237 Answers
Low refrigerant. you'll need to call someone in to recharge it.
Posted on Nov 12, 2009
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
FREEZER COOLING OK BUT FRIDGE LOW COOLING
Remember that most all refrigerators only have cooling to the freezer... the refrigerator depends on stealing some of that cold to be cool, so here's my top 3 guesses...
Cause 1 The defrost heater is defective, so frost accumulates on the evaporator coils, and the coils will become plugged with frost causing the airflow through the coils to be restricted, and the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system after clearing any restrictions to the cooling fan and defrosting with a hair dryer.
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor.
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed or that an inadvertent bump has shut it off to the refrigerator compartment
Apr 09, 2016 | White-Westinghouse WRSZ28V8GM Side-by-Side...
I have a daewoofrg1820brb I've had it plugged in 4 2 hrs now freezer is cold but the bottom isn't getting cold
Cause 2
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, bench test it for function and use a multimeter to test the motor windings for continuity. If the windings do not have continuity, (very odd) replace the evaporator fan motor. Cause 3
Apr 09, 2016 | Refrigerators
WHY IS THERE WATER IN BOTTON OF FREEZER AND ICE MAKER NOT MAKING ANY ICE
You have an iced up evaporator (cooling coil). This coil is usually located in the freezer section. A small fan distributes air across this coil and into the refrigerator. If coil is block with ice, no air can be blown across the coil. Coil is blocked with ice due to failed defrost timer on main circuit board or a failed defrost heater.
Jul 14, 2014 | LG Refrigerators
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
Top coil is freezing up, the remaing coils are not getting cold.
low on freon or plugged to the point of where the frost stops on the evaporator. Evaporator should fully frost up on all coils...
Sep 12, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
