Question about Neff H7871N2GB Convection / Microwave Oven
GE JVM1350WW My unit is not working, no lights, nothing.  I have power to the fuse directly behind the control panel.  The parts list calls out 2 fuses but I can only find one.  The diagram at http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216841 says there are 2 fuses but the drawing only shows one.  Where is the other one?
  • Neff Master
  • 9,098 Answers
That listing is confusing, but they show two fuses but both with the same reference number of 1626.
There are also two thermostats (aka "switch, t-stat") at refs 1430 & 1431 which may be open. They should be normally closed.
One is on the magnetron (the one I suspect) and the other monitors the cooking cavity.
The one on the floor of the chassis should be normally closed. It is the flame sensor.
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting & testing parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
I have a GE profile XL Sensor VM 1350BW that will not go on fuse is ok, any suggestions? thank you
There are 2 thermal limit controls inside that if at any point the microwave got too hot they will go out like a fuse. One is mounted directly on the side of what is called the MAG TUBE directly behind the control panel. The second one is mounted against the cavity either on the left side or on the top middle. These are round thermal limits about the size of a dime with 2 wires attached to each one. Can't tell by looking at them if they are bad. Need an ohm meter to test. I usually jump the 2 wires together for a few seconds to see if if the microwave control panel lights up. If it does thats the bad one. You must replace the bad one since it is a safety feature.
Feb 27, 2015 | GE Microwave Ovens
Have GE Spacemaker XL1800, Had a power outage & now it wont power up. No lights or anything. Checked the 2 fuses behind the control panel & both were good. Any other suggestions or should I just chuck it.
In addition to the fuse(s), it will have one or two thermostats (aka "thermal cutouts" or "TCOs") which can open, resulting in a loss of power.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpg You can see a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Along with the video there, you can find information on getting your controller repaired, if that's what's required.
You find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Oct 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven not working
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE SpaceMaker Microwave Ovens
GE JVM1540sn1ss Microwave loses all power including interior light, control panel, etc. I have to set the clock each time. I can wiggle door or control panel and power comes back on. I appears there...
It may be a loose fuse holder or a rare condition, an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you need further help feel free to contact me with your full model number and symptoms.
Jul 06, 2011 | General Electric Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
Convection microwave oven suddenly stopped
If there is no power to the unit at all, no lights, no nothing, but there is power at the outlet, then you are most likely going to need a new board. the Electronic control board controls everythign on that unit. I woudl call GE direct for service, adn depending how old it is they may be willing to give a parts and or parts & labor concession - they are usually pretty good about that kinda stuff.
Nov 02, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
Intenal Fuses for Lights
In some cases, it may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some cases, a light failure where a bulb shorts can damage the control board itself.
If the problem is on the control panel, we regularly repair these for customers nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me
directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace Thermostat or Thermal fuse
GE calls them TCOs or thermal cutouts.
There are three in this model and they can all be ordered here.
The reference numbers relate to the drawing here.
REF# PART# DESC
111 WB27X1127 TCO -BOTTOM
59 WB27X10195 TCO -CAVITY
104 WB27X10194 TCO - HOOD
101 WB27X10388 FUSE
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. It usually shows relative component layout.
Aug 19, 2008 | Microwave Ovens
Fire in microwave
Seems like I've answered this one, too.
Two 20A fuses?? In a recent GE?
The interlock is a door switch, not a thermostat or thermal fuse. A thermostat will reset (unless defective) but thermal cutouts and thermal fuses are one-time devices.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
William E. Miller, AS-EET
prototech@usa.net
May 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Neff H7871N2GB Convection / Microwave Oven Logo
443 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
