White strip
I have a problem. There is a white strip in my desktop - it is an entrance to internet. But I do not want it - I do not know how to eliminate that. Right click is inactive and left open website links. it appears suddenly - I have change resolution but later on I have return to the same resolution. chris
    Problem Solver:
  • 18 Answers
Goto sturt up ini. and delete the line !
Posted on Nov 16, 2009
My pc shows orange light error
Is it blinking or steady? if it's steady the computer is receiving electrical power, but an internal power problem might exist. Try these:
Make sure the microprocessor power cable is securely connected to the system board, remove and reinstall the memory modules, remove and reinstall any cards....
If blinking try this; make sure the main power cable is securely connected to the system board. Eliminate interference: power extension cables, keyboard and mouse extension cables, too many devices on a power strip, multiple power strips connected to same electrical outlet.
Sep 13, 2013 | Dell Computers & Internet
Faded screen
Hi Isobel,
Not much information there...
iMacs tend to start displaying vertical lines, lie white faded strips as they age.. unfortunately, it's like iMac Alzheimers.. nothing to be done under $600
May 09, 2013 | Apple iMac Computers & Internet
The unit is always Humming. I would like to get a schematic to trouble shoot
It hums because it doesn't know the words (I crack me up).
Do you mean physical hum at the unit or audio hum through speakers?
BTW: no make or model number info came through with your post.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Reverse the cables Left to Right to see if it stays with the cable or the input channel. Follow it back to the source, isolating in the same manner. Eventually you will find the entrance point of the hum. Freqquently a cable
Apr 05, 2011 | Audio Players & Recorders
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Flashing yellow light from start button.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Eliminate interference - Some possible causes of interference are:
  • Power, keyboard, and mouse extension cables
  • Too many devices on a power strip
  • Multiple power strips connected to the same electrical outlet
Sep 30, 2010 | Dell OptiPlex GX280 PC Desktop
I have a hole in my hollow garage door (not the actual car entrance door). It is an outside door. I want to know how to fix it.
If it is on the thin metal piece you will have to use a thin strip of metal like tin or something and either screw, rivet or liquid nail it on. If you were to provide more information you would get a much more detailed answer. Thanks BB
Jul 14, 2010 | YouTube Videos
Eliminate withe strip on the desktop -
right click on the desktop...choose properties...a window will appear...from which ...choose desktop...on this window you will have a button in the lower ..that says customize desktop...click on it ...
now a new window will appear ...that has 2 choices ...first is general ...and in the up left ...you have a choice named WEB ....open it ...and you will have where to uncheck the web page that is locked on desktop....probably named home ...or so ...anyway if there are more than one just clear them all and press aply and ok ..This have to do it ...
Nov 12, 2009 | Dell Computers & Internet
What is this mean
In the scanner unit of the copier there is a white strip that is usually located under the main glass(depending on copy model). The copier shines light (from the bulb on the scan carriage) onto this white strip and reads/measures the reflection coming back from it. The copier knows that this strip should be white (which would be specific value stored in the copier) so to maintain copy quality the copier keeps referencing this strip to make sure it keeps the "white" value and does not loose sight of what white is supposed to be. If the strip becomes dirty/faded/scratched or missing a piece then you will notice a drop in copy quality.
If you were to stick a small black piece of tape onto the white strip the copier will still think that the black tape is supposed to be white but its value in reading the black tape will be completely different to the value it receives from the rest of the white strip. If you now made a blank copy you would get a black line showing up corresponding to the place where you stuck the black tape. BUT the copier still thinks its all white.
May sound a little confusing? but that's the just of it.
Jan 14, 2009 | Sharp AR-407 Copier
Prints extra strip in between
try to reset the settings in the printer panel inside the printer setup menu. try to choose the initialize all. then observe your printer operation.
Jan 10, 2008 | Epson Stylus Pro 9600 InkJet Printer
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
