Question about Motorola Mobility RAZR V3
Battery not staying charged
I have bought a couple of new batteries hoping the first one I bought just wasn't a good one. So, is it possible that it's the charger? My phone only stays charged a few hours.
  • yramir Jan 08, 2008
    Thank you so much for your help.
  • 54 Answers
What kind of reception do you have in your area? If you don't have good reception it can really kill your battery. Is your bluetooth on all the time thats also a battery killer. Those a re the two i see the most in the shop. How much time do you talk on your phone? If you can get more than 2 hrs talk time the phone is actually doing pretty well. Mine straight out of the box only got about 16hrs on a charge. 6 - 8 hrs if i talked a lot!
Anyway there may not be much wrong. Just check your reception and see if your bluetooth is on all the time. Good Luck!
Posted on Jan 08, 2008
I bought new gel batteries to replace the old gel batteries for my chair. Charged them for a day and a half and they showed to be fully charged. Used it for about an hour and it went dead. Old batteries...
Hello,I would get back to where you purchased the batteries and go from there.Take the charger also to ask them to test it,also keep the old batteries as they are as you say.Still okay.Take care and I hope this helped you.Colin
Mar 27, 2015 | Invacare Pronto M51 Power Wheelchair
We bought two new battery's a new alternator checked all fusible links from alternator to battery. Truck only runs for a few days with battery light on then we have to charge the battery. It's an 2004
open or shorted alternator circuit (control wire)
let your auto store test the alternator charging
on and off the truck.
inspect 3 wire connector for burn or lose connection
disconnect 3 pin wire and start the engine.if the light stay on you have shot to ground.
Mar 25, 2014 | Ford Cars & Trucks
Nikon coolpix s205My camera wont charge any more. I had it stored for about 6 months and when I plug in the charger the light pulses with a green light then a solid green light for a couple seconds th
The manual says, when the light is flashing green:
The USB cable or Charging AC Adapter is not properly connected, or there is a problem with the battery. Disconnect the USB cable or unplug the Charging AC Adapter and correctly connect it again, or change the battery.
So make sure you are using a good USB cable, the cable is put in correct. (far enough and straight) And I hope you did not put in the battery the wrong way around, because that could cause damage to the camera and battery.
Make sure the battery and the camera do have clean and shiny contacts. Only to clean with a dry cloth.
And if the problem stays, perhaps you should accept the battery is dead.
You could try to charge it on an external charger, if you have one. And start and stop charging, if you think it is not yet charging.
But if after just a few attempts nothing changes, I think you should buy a new battery.
Jan 22, 2014 | Cameras
71 c10 not staying charged... new battery alternator fuses good and new voltage regulator
Maybe it wasn't running long enough to charge up the battery?
Stop trying to jump it, when you are having problems with it dying, take the battery off and have it charged. And/or buy a $20 voltmeter to see what the battery shows. If it says less than 12 volts, it is discharged, and needs charging. A good battery that is not run down should have at least 12.5 volts. A new battery that is charged should have very close to 13 volts, maybe 12.8 volts.
When you have the truck running, check the alternator for charging. You put the voltmeter right on the battery and check it again. This time, with truck running, battery should show at least 13.5 volts. That shows the alternator is working. A good alternator will put out about 13 or 14 volts-the regulator will keep it from going any higher to prevent problems, like a melting battery or electrical parts burning out.
I would say get the charging system working right, then address the problem of dying at stop lights. That could be a carburetor problem, if the alternator is working.
Aug 15, 2013 | Chevrolet Cars & Trucks
My brake light and battery lights keep coming on. I replaced my battery and that fixed it for a couple of days and now the problem returned.
your alternator isn't charging the battery enough ,, clean and tighten all battery connections, clean the posts ,, , there have been times when I've purchased a new battery it just wasn't up to par,, take it back,, have them load check the battery , this will tell you if the battery has a bad cell in it, if it does,, have them replace the one you bought, once you have a known good battery installed in your car,, start the motor and with a multimeter test the battery posts,, Place the Positive on the + side of the battery , and the neg - lead on the battery, with the motor running, you should get a reading of 13.5-14.5 volts, if your getting less than that first reading, your alternator is shot and will need to be replaced
Aug 28, 2011 | 2002 Subaru Outback
Battery wont stay charged, alternator problem?
I suggest that you take the car to an autoparts store and have them check the alternator output. That will tell whether the alternator is putting out sufficient voltage to keep the battery charged or not. Most parts stores will check the alternator for free. Hope this helped and best wishes.
Sep 15, 2009 | 2001 Volkswagen Beetle
Dell Inspiron B130 Battery Problem
Sounds like the cells in the battery went bad. Try to turn on your laptop with just the ac adaptor hooked up and your battery out off the laptop to make sure that your ac adaptor is working properly. If you can boot up into windows with just the ac adaptor hooked up then you know your ac adaptor is good.
If you get that far then try a different battery and see if the laptop charges with another known good battery. If it does then you know your original battery is bad. If it doesn't charge your different known good battery then you know the motherboard is bad. Hope this helps.
Ben
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Motorola Mobility RAZR V3 Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
