Fried acer L310
I think i just got the dvd drive cable on my aspire L310 shot circuit with a metal part of the chasis body after upgrading my ram to higher capacity,from there onwards only my power adapter lite up,the rest of the internals no activity..Pls help..!!
    Novelist:
  • 186 Answers
Try putting your older ram back in. If it works, you'll have to check your upgrade modules and whether your board will accept it.
Posted on Nov 13, 2009
Does Acer Aspire L310 support Intel E7500 CPU?
Visit the following website and download the user manual. Read the upgrade section. It will tell you what you can upgrade.
http://www.acer.com/ac/en/US/content/support-product/333;-;Aspire%20L310
Nov 10, 2015 | Acer Computers & Internet
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
How do you install 2 gb memory in acer aspire one D255
vtxgreg, I typed out a lengthy solution to replace Ram Memory in an Acer Aspire One D255, but after looking through it once finished, I thought this to be the better solution.
1) Video of how to remove the Keyboard,
http://www.youtube.com/watch?v=FoTwln2SyQ4
[ NOTE*
I advise against using a utility knife blade. That's just Dumb! Use a small flat tipped Jewelers screwdriver.
I also advise buying, and wearing an ESD wrist strap. Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
(You probably won't even see it, or feel it)
Connect the alligator clip to a good ground source.
{I connect to the metal frame of an empty desktop computer case}
Price for an ESD wrist strap averages around $3 to $6.
Here is an example of one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16899339002&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Tools+-+Network+/+PC+Service+/+Acc.-_-Cables+Unlimited-_-99339002
(You can get them cheaper as I stated above)
2) Video of how to replace Ram Memory in an Acer Aspire One,
http://www.djody.com/acer-aspire-one-memory-upgrading/
Use a multi-compartment container for the various screws you will remove.
mark each compartment for the area the screws come out of.
A LOT of the screws look VERY similar to others, but they are NOT.
Do Not mix them up!
If a multi-compartment container is not available, you can use a clean egg carton in a pinch. Mark each egg holder.
Nov 28, 2010 | Acer Computers & Internet
How do I access the memory boards in the Acer Aspire 5315 Notebook pc?
1) Remove ALL electrical power to the laptop. The AC adapter (Charger) and Battery.
2) Open the laptop, press the Power On button, and hold it in for a count of 5 seconds. (Removes residual power)
3) Close the laptop, turn it over. Remove the 'Thermal Door'. This is a large panel on the back of the laptop. There are several Philips head screws to remove, going around the outer perimeter of the panel.
http://members.aceweb.com/gregg1/acer/Inside_Acer_Aspire_5315.html
Here you will see the panel removed, and the ram memory compartment marked.
Handle a Ram Memory module ('Stick') by the body, and refrain from touching the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Your body carries Static electricity, and Static will fry out (Short Circuit) the hardware components inside a computer.
There are two ram memory slots.
There are two metal clips that hold a ram memory module in place.
One on each side of the ram memory module. Look at the sides of the ram memory module, where the metal clips press against.
Each metal clip has a rounded 'knob' that fits inside a Notch, on the sides of the ram memory module.
Use the fingernails of one hand, to ease out on the 'knob' of one clip, while doing the same to the other clip, with the other hand.
(Ease the clips out away from the ram memory module)
Once the clip's knob is free from the notch of the ram memory module, the ram memory module should slightly pop up on one side.
Lift the side that comes up, to a slight angle, then keeping it at that angle, remove it.
NOTE*
DO NOT lift straight up on the ram memory module, or you'll damage the connecting pins in the ram slot.
(And the gold plated contact pins on the ram memory module)
To replace line the ram memory module up at the angle you removed the old one.
Slide it down in the ram slot.
Then gently spread the metal clips, and ensure they are seated in the notches at each end of the ram memory module.
For further questions please state in a Comment.
Regards,
joecoolvette
Nov 03, 2010 | Acer Aspire 5315 Notebook
How to Open a case
Acer Aspire RC900?
1) Computer off, unplug the power cable from the surge protector. Now unplug it from the computer (Power Supply)
(Unplugging the power cord from the back of the computer, while still plugged into the surge protector, may cause a voltage spike.
This could result in frying out the Power Supply, and may also fry out the Motherboard, Processor, Ram Memory, and Graphics)
2) Viewing the Acer Aspire RC900 from the Front, the Left side panel, is the panel that removes.
3) Viewing the Acer Aspire RC900 from the rear, look at the right side. (Left side actually, but now the computer is turned around)
There is a Cover Release Latch that is close to the outside edge, and towards the top.
It is whitish in color, and approximately 1-1/2 finger digits long, and half a finger digit wide.
(Universal measurement I figure. Using the Inch system it is approximately 1-1/2 inches long, and 1/2 inch wide)
Pull this Cover Release Latch to the right. (Towards the bottom of the computer if it were standing up)
You will see that this side cover, has a formed shape that you can put your fingers in, to pull the side cover towards the rear of the computer.
Pull the side cover back towards the rear of the computer to remove it.
Advise:
Static can fry out (Short Circuit) the hardware components inside a computer.
Touch the metal frame of the open computer case BEFORE you reach inside, to relieve your body of Static.
(Not shouting)
If you get up, walk away, then return, Touch the metal frame again.
Computer unplugged from power, you are safe.
Touch the metal frame of the open computer case, your computer is safe.
Have any more questions concerning this, I'm right here. Please post in a Comment.
Regards, joecoolvette.
Feb 07, 2010 | Acer Aspire RC900 (91.PJB6P.UE7) PC...
How to put CD in L310 acer
Looks like you have a slot-loading DVD±RW drive just like the one that would be in a car. Just press cd into **** and wait for it to grab cd. Looks from the picture like there is a button next to it to extract it. Good luck.
Nov 07, 2009 | Acer Aspire L310 Desktop
Max processor for upgrade?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Theoretically, it's support up to Core2Duo with 1066 Front Side Bus, but some source in Intel Website said that it's chipset (Intel946GZ) can afford until Core2Duo E7500 (1066FSB), to be honest, my L310 using E6300 which is have 1066mhz FSB. So I think it should be ok if run with higher Core2Duo, but I suggest to do bios firmware update before change your processor.
Apr 07, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Difficulty locating memory chips in my Acer Aspire L310
visit youtube web,, there so many video how to install ram or laptop desktop hardware installation
Jan 08, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
