Question about Microsoft Xbox 360 Elite Console
Switches on and where u switch it on a red light
Switches on and where u switch it on a red light is going round instead of a green one says contat support
  • 33 Answers
Plug in your video and audio cord firmly in the console and turn it back on that should fix it
Posted on Nov 22, 2009
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
GE digital timer 15313 has 3 wires, black, blue and green. Wall switch wires have bare, black, red and white from one line, and black and white from the other line. I've tried every combination
It sounds like you are replacing 3-way switch.
Low voltage light? Are these lights connected to 120Volt circuit?
I think you want the GE 15312 timer, instead of GE 15313.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
GE 15313 is for single-pole incandescent light bulbs only.
This is live answer 11-2012
Add a comment for more interaction on answer.
Nov 22, 2012 | Hardware & Accessories
Every time i switch on my 360 it has a red halo round on button instead of the usual green and wont switch on
Try this:
  • Disconnect and reconnect the A/V cable. Make sure the A/V connectors match the colors of the component video, the composite video, and audio ports on your television. Turn your television and console back on.
  • Try a different A/V cable. If still the same thing your console needs to be repaired. Contact Xbox Support at (800) 4MY-XBOX or (800) 469-9269
Mar 30, 2011 | Microsoft Xbox 360 Console
Have a red, green, white and black wire on ceiling fan. have white, black and bear in ceiling. need to know which wires to hook together to make it work properly
The black Should be the hot (load) wire....so black to black.
The white should be the netural...so white to white.
The bare wire is the ground...it should go to the green in the fan.
Normaly the light wire is blue though in this case it must be red.....so it should go to the black wire that the fan is tied down to... unless you have a black wire coming from the wall switch. Then it should go to that black wire. This lets you turn on the light from the switch instead of the chain.
Nov 23, 2010 | Garden
My packard bell ixtreme 5830 wont turn on. the light stays orange instead of green can anyone help
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Jun 11, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
My break lights wont go off
the brake lights work off a switch which is located by the brake pedal. the switch has a burnt contat that has welded itself to the connecting contact to turn on the power to the brake lights. If you replace that switch all will be back to normal again
Mar 18, 2010 | 1994 Dodge Intrepid
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
How to connect light switch
Nope, you have the wrong type of switch. The old one is what is called a 3-way switch. You need to purchase a replacement 3-way. The switch you currently have is a standard on/off switch and can not be used in that situation.
Dan
Dec 31, 2008 | Cooper Lighting Lighted Switch
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Microsoft Xbox 360 Elite Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
