Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a 1969 John Deere 4020 that is cold blooded. It turns over fast, but won't start without being pluged in or using ether below 70 degrees. What are the potential problems?
  • 486 Answers
Cylinder Compression Low, Valves worn ... not seating properly, valve stems.
Injector nozzles worn ... dribbling rather than precise squirts, injection pump worn.
First and easiest thing to do: pull all nozzles and have them tested, pull the injection pump and have it rebuilt and re-calibrated.
*NOTE: you can pull these, but are components that proffessional need to rebuild and calibrate. Truck shop, or farm tractor shops have places that specialize in this type of work.
If it is gasoline, I would look towards pistons, rings, valves.
Posted on Nov 12, 2009
Need a Harmonic balancer puller for 4020 John Deere tractor
Your local Jd dealer can get you service guard tool for that specific pulley or they can advise you on how to remove it. Some dealers may loan you the tool. Just depending on dealer.
May 19, 2015 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
JD 1630 turns over but won't start
John Deere 3179DL-01
diesel
3-cylinder
liquid-cooled
179 ci [2.9 L]
What is the Temp. in degrees outside. if below 35 degrees it will
be a problem. Some tractors are cold natured and a diesel needs
plenty of cranking amps to start. Have you tried either ?
If you do try either, crank the engine before you squirt it into the breather, and only a small amount. Either is hard on engines
this is why you use it sparingly.
May 27, 2014 | Peg Perego John Deere Farm Tractor and...
Wiring diagram 1969 4020 john deere deasel tractor
Usually there are forums specifically for a brand and even models. I would seek help there. Also look on Ebay. Have you asked a dealership? They might even scan and send you images.
Aug 27, 2013 | Vehicle Parts & Accessories
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Diagram for the battery wiring on a 1969 JD 4020
If yoe are still useing two 6v. batteries then the cables go;positive from the starter solenoid to the closest batteries positive post,the negative post of that same battery feeds over to the next batteries positive post,then join the negative to the engine block or tractor frame.If now has 12v. batteries then join up the positive with the positive posts and join the negatives to ground.If the tractor has a 24v system,[not familiar with the tractor ,none in this area and don't have service advisor here at home],hook the twelves up as i previously stated for the 6v batteries.Let me know if you need more help and i can look it up at work for you.
Nov 24, 2009 | John Deere 4020 Gas & Diesel Tractor...
Blades turn but not fast enough to cut grass
sounds like one or two ploblems,,, change belt,,check tenion pully,,hope this help,, good luck
Aug 06, 2009 | John Deere 4020 Gas & Diesel Tractor...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
283 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
