Question about LG 32LG30 32 in. LCD HDTV
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no problem, but they have different makes of TV with analogue buttons on their hand sets. There is no analogue button on my handset. I had no problem getting analogue on my Sony TV connected to the same arial. Help! Many thanks.
    President:
  • 1,284 Answers
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Posted on Nov 12, 2009
My cello tv won't tune in at all. Every time I try auto tune it goes through the process of tuning then says no signal.
Auto tune would be for the old analogue TV system I believe. Does the aerial connect through a box or direct to the TV? The Sky box should connect through scart (very old) or HDMI which you just need to choose the right input for. Look for a button on your remote for input or an icon that looks like a screen with an arrow pointing into the middle.
Feb 18, 2018 | Televison & Video
'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Sep 14, 2007 | Westinghouse LTV-19W3 19 in. LCD...
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
My Denon AVR1611 powers up and the TV sound works just fine, but after 5 seconds or so the sound quits and I have to press the quick select sat/cable button to start it up again.
hi,
There are two types of input for sat/cable in your amplifier. One is the Digital input and the other is the Analogue input. You didn't specified which one is currently used by you.
However, if you connect the digital input then you have to configure the input assignment to digital and for analogue input configure as analogue.
If you use analogue input and input assignment is in digital mode then the problem mentioned by you can occur.
First of all check the input assignment for sat cable. for that do the following
1. Press the menu button on the amplifier's remote.
2. Select input setup
3.select input assinment ( check the input assignment for sat/cable, If you are using the analogue
input select it as analogue,if your are using the digital input then select it as digital.
ok
Feb 17, 2011 | Denon AVR1611 5 Channels Receiver
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
I cannot get the VCR/DVD to record from my tv. I have a satellite dish. The input from the dish receiver to the tv is HDMI1. The DVD receiver hooks into the AV1 inputs. I can set the timer, but nothing...
I have no direct experience but you should note no recording will take place unless the signal format is suitable/compatible. HDMI is a digital signal and your VCR/DVD will probably require an analogue signal.
A tv processes the digital into analogue but sockets at the back of tv sets tend to be input only. A minority of tv sets have two scart sockets, the second one usually providing an output sound and video of what is playing on the tv at the time.
I believe it is possible to buy a box that will convert digital to analogue or vice-versa.
Nov 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
HOW DO I CONNECT A VCR AND WHAT DO i SET THE INPUT ON.
If you have connected using the coax (aerial) ten the problem will be that the vcr is analogue and the tv is digital(if you have an older digital tv it should have an analogue tuner so you can set it to analogue and tune to the vcr) I suggest using a scart cable from the vcr to the tv, then you just press av on the remote(on some you can just change the channel down from 1 to the av inputs).
Jan 02, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
LG 32LG30 32 in. LCD HDTV Logo
253 people viewed this question
Computer Repairing
Computer Repairing
