Question about HP Laserjet 2605 Printer
Printer puts down a layer of toner on every page so page looks like it has a grey background
  • 55 Answers
Hi jeaston240,
are you using OEM toner if not that could be your problem, or you just might need to change the toner cart. and have the printer cleaned.
Good luck
Posted on Nov 12, 2009
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
The printed sheets come with a layer of black or grey over the print and that on both sides. So I tok out the toner unit and cleaned the inside of the printer with a vacuum cleaner. After a few pages I...
this toner cartridge sounds like it needs replaced. but here are a couple of things to check. pull the toner out open both doors and slowly lower the top cover while watching the charge roller as it comes down make sure its comming down straight. apply a slight upward pressure on this roller to insure that spring tension is present. also the lower roller (transfer roller) press down on this to check for spring pressure. the high voltage may also be the cause of this if its not putting out the right charge
Mar 15, 2010 | Lexmark Optra T610 Laser Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Toshiba eStudio 210c grey background on copies
U need to check your developer material. How many copiers has been made?
U can also perform 05-200 for the auto toner adjustment. The value should be in the range of 235-245% ( 2.35v - 2.45v )
Mar 26, 2009 | Toshiba e-Studio 232 Black and White...
Gray background
if you have a laser printer you may need to clean the printer or install a new drum cartridge, if it is ink-jet you will have to clean the bottom of the ink cradle it sound like you getting grey background from a toner/drum cartridge.
good Luck
Let em know if this helps.
Jan 29, 2009 | HP LaserJet 1200 Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Grey background and dark streaks
Change out the toner first and then the drum. Also be sure there is not excess toner underneath where the toner is installed. If so clean that out with a dry cloth.
Apr 18, 2008 | Brother HL-2070N Laser Printer
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
HP Laserjet 2605 Printer Logo
125 people viewed this question
Seeker5211
Seeker5211
