Question about HP DeskJet 5550 InkJet Printer
Printer won't work
I had a paper jam and both lights were blinking. I removed the paper and now the printer arm won't move. I took both cartriges out as suggested, but nothing changed. Help!
    Scholar:
  • 95 Answers
How did you clear the paper jam? I noticed you must do it from the back.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09363&lc=en&cc=us&dlc=en&product=71896&rule=24789&lang=en
Either the back was not put back on correctly or something may have been damaged while clearing the paper jam. Please power off printer unplug it from wall. Wait 5 min the plug it back in. If heads don't recycle something has been damaged. Are there any lights flashing? Please let me know if this helps if not let me know the steps that you have taken and I will try to help from there.
Posted on Jan 08, 2008
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam in canon printer mx432
I took Ekse suggestion to start off with by turning off the printer; opening the front cover and removing the ink cartridges. Behind where the color cartridge goes is a light blue wheel. I took a letter opener and gently tried to move it. It moved and after a few turns it loosened the paper and I was able to gently removed the whole sheet of paper. I'm by far a techy but have been known to take care of paper jams. This little machine had me baffled because the back was of no use like other machines.
Jul 05, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Both paper and cartrige lights blink & E in coppies won't leave
just replace the cartridges its the cartridge replacement error .or check out in the printer for any paper jam that also gives this E error on the printer.but mostly its the cartridges error.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer is totally jammed
check whether any paper is jammed you can remove the jammed paper from the back of the printer .there is a assess door which can be easily removed and from there you can check if there is any paper jam and you can remove.if there is no paper jam and you still face the problem.it is necessary to open the printer and service the parts and oil the gears to make the printer move fluently.you can do it your self if you have proper screw driver it does not require any thing execpt a proper screw driver to disassemble the printer.or you can take it to any proper service center and it will work properly after it is serviced.
Sep 05, 2008 | HP DeskJet F380 All-In-One Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
Paper jam
well..you may need to remove the software, and re install it...
and also, unplug the printer for around 5 min
May 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
