Question about Brother MFC-7220 All-In-One Laser Printer
Memory error How do I clear the "fax in memory: 20" Brother MFC-3360C
    President:
  • 405 Answers
Unplug the MFC from power for 5 minutes
Posted on Mar 29, 2010
How to clear fax memory in Brother MFC-9970
Check the manual Chapter 3 Pages: 20 thru 24 That should help you. Here is a link to the manual.
https://www.brother-usa.com/VirData/Content/en-US%5CMFC%5CConsumer%5CUsersManual%5CUM_MFC_9970CDW_EN_2755.PDF
May 27, 2014 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 3360 C can not send fax.It show "sending" ....thats all never finished.
When my fax machine does this, it prints out an error code. Most of the times it's "Poor transmission" or "Bad line". I can duplicate the problem by trying to fax out on my VoIP line instead of my regular land line.
Anymore today, it's usually easier to scan and email the document. I can e-fax the scan if I'm sending it to someone without an email address.
Carl
Jul 10, 2011 | Brother Multi-Function Center MFC-3360c...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
How to clear the memory on a brother mfc-240c-- error when faxing is out of memory
You can also try to send the fax with Real Time Transmission ON so that memory will not be full.
Sending in real time for all faxes
a Make sure you are in Fax mode . b Press Menu, 2, 2, 3. 3.Real Time TX Realtime TX:On
c Press a or b to choose Realtime TX:On or Realtime TX:Off.
Press OK.
Please click Yes if this helped
Thanks,
vikroks
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 3360C
Try turning off ECM (error correction mode or overseas mode). Try calling the fax # from a regular phone line - If you hear the fax shrill tones you know you've got the right #) I it does not go through, you should get an error code #. let me know what it is
May 02, 2007 | Brother MFC-3340CN All-In-One InkJet...
Brother MFC-7220 All-In-One Laser Printer Logo
171 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
