TOSHIBA 32WLT68, STUCK IN STANDBY, I HAVE LOOKED AT THE POWER SUPPLY AND IT LOOKS OK!HOW CAN I TEST THE SUPPLY?
  • 117 Answers
Order a repair kit or send it to [ohm supplies] cheap repair/ if u no how put a meter on output pins beware of shock even if unpluged
Posted on Nov 12, 2009
Testimonial: "sound info many thanks"
  • 458 Answers
Replaced main board
Testimonial: "sound info many thanks, but why the main board what about the power supply?"
  • tvservice306
    tvservice306 Nov 13, 2009
    if power dead not standby.
    if you need part try
    Order by phone 1-888-BESTBUY (237-8289)
I have a toshiba tv model 42xv545u that has no power. No standby lights, no fan nothing. I checked the fuses and they are good. What now
maybe the dog chewed the power cord... It is probably the main board, probably cheaper to get a new telly than try and get it fixed.
Mar 31, 2018 | Toshiba Televison & Video
Flat screen tv stuck on standby
Low power output problem. Open the back cover. Look for the power supply board. Look for faulty capacitors. If found replace all the caps at the output area and test. Should work
Jan 10, 2015 | Televison & Video
TV stuck in standby
have you looked at power supply as you might have to change the caps on the power supply
Jan 25, 2014 | Bush Industries IDLCD26TV16HD LCD TV
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Hi, i have a toshiba 32wlt68 stuck in standby,i have fitted a new power board, still the same! but if i unplug the tv and hold the power button for a short time plug back in i can get out of standby,and...
Okay, this may a silly thought but, was there a switch or a dip switch on this replacement board you recieved. It may be in switched into the Service mode?
Just a thought.
Blessings,
A/V Media Guy
Nov 21, 2009 | Televison & Video
I have a toshiba 32wlt68 stuck in standby help!!
At least you have the 5vdc standby circuit working, the controller board may not be sending the ON command to the main power supply, or the main power supply itself is bad. Look at the main power supply module first for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 11, 2009 | Televison & Video
No power
Do you get any indicator lights at all? If you do, the at least the 5v standby circuit is still working. Check the power supply fuse first, then look for 5v standby voltage, if you do have the 5V, then the problem can be in the controller board not sending the ON command to the main power supply when the power switch is activated, OR the main power supply is bad. Look for bad capacitors or bad/burnt parts.
http://en.wikipedia.org/wiki/Capacitor_plague.
Nov 06, 2009 | Toshiba 32HL95 32 in. LCD TV/HD Combo
I have a Toshiba model 32WLT68,which will not switch on
Have the main power supply module checked out first.
Oct 29, 2009 | Televison & Video
No power
It seems like my toshiba goes into, stanby... i plug it up, and the standby light just flashes.. for a while, and then it stops until i unplug it and plug it back up... it will not come on...
Its like its in standby mold..
Does it need a new lamp..
I looked at the lamp, and it look like it was ok, but i did notice something they may look like bubbles, or something inside, im not sure though...
Feb 22, 2008 | Toshiba TDP-S8 Multimedia Projector
Televison & Video Logo
712 people viewed this question
Top Televison & Video Experts
