Question about Mitsubishi WD-73732 73" Television
The set has a great picture for about 15 minutes then the color starts to become fuzzy. We have changed the bulb. What is the other possible problem. I am thinking overheating. Please advise
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Pleasecheck if the connections of the bulb are not loose and wires are not cut fromplaces. If the wires are fine then make sure that there is no spilled plasmaon the board. If that is not the issue, then you’ll need to check theconvergence ICs (STK IC). There are two ICs located on the D Board of the TVand there are two Pico Fuses near them (they look like small resistors). TheseICs and fuses will cost you around $40-50. For replacing the STK ICs alsoreplace these fuses. Please see the link for how to replace the STK ICs. You’llneed to use soldering iron to de solder and solder these parts.
STK ICreplacement
Note--Please make sure to turn off and unplug the TV for at least 1 hour(this will drain off current from all components especially capacitors) beforeyou perform any repairs. Also note that the TV consists of very high voltageseven when it is in OFF condition.
Please doaccept the solution if the issue is resolved or else revert for furtherassistance.
Thanks
Rylee
Posted on Nov 12, 2009
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
Curtis Mathes TV
the convergence ic must be faulty
Mar 01, 2008 | Televison & Video
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Poor picture
adjust the antenna! or the cable connection could just be loose or dirty!
Jun 18, 2009 | Televison & Video
Computer monitor doesn't show colors good only white and blue
Drivers not installed properlyu...install properly the driver, if then same proble check the VGA card for the desktop/ vga chepset chep in laptop.. or cable connection og vga...
May 31, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
Mitsubishi medallion 65" hdtv
the dm module power supply is developing leaky capacitors and will eventually cause the set to not come on at all. this may also be causing the snowy picture if you are useing the digital tuner. The dm module will require repair to resolve these issues.
Nov 29, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WD-73732 73" Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
