Vcr audio out
Can I drive a external speaker from the vcr audio out?
  • 579 Answers
No, it is just a line level output and can't handle a speaker directly. You need to run it through a stereo amp or maybe some of those powered speakers.
Posted on Jan 08, 2008
I have a sb wa340 active subwoofer. I have subwoofer and speakers but I don't have DVD how can I use this
So is the DVD part missing? There is a VCR / Aux input on the back but it is for audio only. There are no video inputs so if the DVD is not included in your sub/speaker system, you'll be limited to audio only. First, you'll need to connect a TV to your system using one 'Video Out' cable methods so you can see the menu for the remote control changes on the system. From here there are 2 options:
  1. Connect up a working DVD player directly to your TV using the best option available. Use the audio outputs on your TV to connect to the VCR or TV input on the system box. (Using standard RCA cables.) You may need to enable the external audio outputs on the TV. (Check the setup -> audio menus etc.)
  2. You can use this as an audio amp by connecting a RCA cord from the a DVD R/L audio outputs to the VCR-Aux input on the amp box. You will need to run a separate video feed from the DVD directly to your TV. (Select the desired input on the TV to watch a DVD.)
You'll need to do a lot of switching back and forth with multiple remotes to get everything working, but the speaker setup can be made useful if it still works.
Here is a manual for the system: http://service.us.panasonic.com/OPERMANPDF/SCMT1.PDF
Mar 13, 2015 | Audio Players & Recorders
Why am i getting No picture only audio when vcr connected to tv?
If you are using 3 RCA cables to connect your VCR to your TV, make sure you have the video cable (usually yellow) well connected at both ends. Video Out from VCR to Video In on your TV (also usually yellow).
Also, depending on the brand of VCR, make sure you don't have an option for external speakers connected. This would eliminate the video too.
Hope this helps.
Jul 30, 2014 | Televison & Video
No video or sound
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 27, 2011 | Nintendo Super NES Console
I came home today and my external audio speakers were not working...I hear a little ***** sound through the speakers when I switch to them. It is the Home theater system DAV-TZ2510 The DVD Player plays...
Hi, Check too see that somehow a " TAPE MON." button did not get pressed. having the tape monitor engaged will null anything but a tape fronm being played. or it even could be calle vcr mon. but either way peculiar problem. I hope this helps, let us know if it did,write back too if not. Good luck, Prodzilla
Apr 13, 2011 | Sony Audio Players & Recorders
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
Turn the power on.
Feb 10, 2011 | Nintendo 64 Console
How to conect my vcr to the tv
Depending on the VCR use an S-video cable with the RCA audio cables or the three RCA (Red and white audio and the yellow video) AV option. Attach them from the output of the VCR to the inputs of the television. The audio in jacks are the ones on the bottom; the upper ones are audio out for external speakers.
Also connect the antenna out (RF) from the VCR to the TV if the VCR has a tuner. (Incoming signal goes to the VCR if you are using this option).
I hope this helps.
(the TV has no HDMI or component video)
Jun 19, 2010 | Zenith C27A24T 27" TV
No audio from analog audio outputs on denon 988
When you use VCR or DVR out, you must also turn on the VCR/Video 2 Tape Monitor function on the front input select, then it will pass audio. IF you need further help, post a comment and I can pull the specs on your receiver and help some more. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
Aquos LC-32D43U, no audio
My suggestion would be to bypass all of your video components whatever you have be it a vcr, dvd player,whatever and just hookup the tv direct to whomever you receive your cable tv from. Because it was working before you moved it and disconnected the external audio source. Remember if your using HDMI cables they are your audio and video together and you don't need to hookup anything else from that device to the tv. Just FYI. Good luck.
Jun 19, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
19 inch LCD TV
Hi, Chances the Audio L/R are line level (can not drive speakers) other than they can either be output or inputs. If they are inputs, they are connected to a source such as a DVD player or if they are outputs, connects to an external amplifier where external speakers maybe connected. hope this be of some help/idea. Post should you need additional information. Good luck and kind regards.
Aug 25, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Televison & Video Logo
Top Televison & Video Experts
