Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Red Vertical Lines - Sony Grand Wega 42"
Actual model is sony Grand Wega KF42WE620. I am getting red vertical lines across the screen...thicker on the left side. Sometimes they come & go, but they seem to be there constantly now. I tried unplugging the tv for a couple of hours so it could reset itself...it worked for about 1 day & then the lines were back.
What would the issue be?
  • theresa_sawy Nov 13, 2009
    I went to the website you suggested but couldn't find anything? Is there a particular area of that page that I'm supposed to look? All the menu items seemed to be "Watch News TV", "Watch Sports TV", etc.??
ctf1800
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
SOURCE: SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
check standby power supply caps (elec. type probably swollen) after that then it's the q box
Posted on Jun 29, 2008
SOURCE: vertical multicolored lines covering the whole screen
Just a shot in the dark, but if you are using component video cables, double check that they are in the correct inputs and outputs. If this doesn't work or you are not using component video cables then I don't have any other ideas as of now.
Posted on Nov 27, 2008
  • 179 Answers
SOURCE: 60 inch Sony Grand Wega
no, it is not the lamp,the DIC 2 board is bad.in this case it is best to have a sony certified technician come out to give you an estimate. the board is expensive and the lvds cables attached to it are verrrry
fragile and expensive also.
Posted on Feb 06, 2009
SOURCE: Sony Grand Wega kdf-42we655
who ever has problem with rear pj tv's here a simple thing that the manufactoring wont tell that there are vents on these units and filter that needs to be cleaned every month and if you have hairy pets more often. the thing that happening is the system is getting no air
and the lcd is burning up i know this because i've taking them apart
over and over its the same reaction you get for leaving you laptop pc in the sun or in cold weather. extreme enviroment is the culprit. if you see these problems its big money other wise cleaning these vents and filter gives you long life to lamp and the lcds difsusion plate would do something else.
Posted on May 14, 2009
The picture in my Sony Wega is not nearly as clear as before.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red lines
That sounds like a bad convergence board, they cause red lines like that when they go bad. Lemme see if I can find some specifics on your model, and getting parts for it.
Sep 02, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
42" red light on, dim light appears on screen. bulb just replaced
Sony has had alot of problems with the light engines
and your set is DLP. Call Encompass Parts Distrubtion for Part number and Price then go to E-Bay look under Electronics tpye in part number .I have found same Parts Alot cheaper on Ebay,some by as much as $300.00
you can Google website or call 1-800-638-3328
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony 60" SXRD60HZ285WMAX Rear Projection, has a green tint and can't be ajusted out.
I have a sony grand wega and there are red lines going vertically across the entire screen.
Mar 03, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
