Question about Dell E197FP LCD Monitor
Monitor diplays full screen alternating different colors
Monitor goes through solid color wall to wall alternating colors when computer is turned off and the monitor is left on or when the computer is on and left idle for a while
JMuskovitz
  • 135 Answers
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
  • 75 Answers
SOURCE: Scanport Monitor problems
can u describe me wat typ of monitor u use?
if a crt monitor just resolder the whole circuit board..
Posted on Feb 22, 2008
  • 23 Answers
SOURCE: Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Posted on Jul 12, 2008
SOURCE: Dell E177FP monitor won't turn off in power saving mode
I had the same problem and I went to the first button on the monitor to the left(main menu) then with the button to the right (-) I scrolled down to factory reset. I also did the osd setting and I'm not sure what fixed it, but I havn't had the problem sence.
Posted on Feb 28, 2009
bob_computer
  • 3153 Answers
SOURCE: switched monitor to a different computer and color
are you sure you cant alter the settings via OSD ?
If not then http://www.normankoren.com/makingfineprints1A.html
Posted on Aug 10, 2009
My monitor diplays lots of blue color
Sunshine versis darker room maybe?
Mar 11, 2015 | HP W2007 Desktop Monitor
Screen goes black or pixelates
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Can my LCD monitor damage if I place multimedia speakers near it?
No this happens in the machines that with CRT, LCD is free from this thingy as LCDs don't use magnetics to steer the non-existant electron beam.
The only danger might be if they produce a large alternating field, as this could induce currents in nearby wiring, but this an't gona happen.
Regards, Waqar.
Sep 23, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Laptop screen freezes in different color
This is definately an over heat issue. since laptops use on onboard graphics card, chances are you might need to replace the mother board, or may it may just need a fan replacement. also purchase a laptop cooling pad
Jan 27, 2009 | Compaq Presario 700 470024-192 Notebook
Monitor flashes 7 or 8 separate colors
Your monitor's inverter board is a toast you will have to replace it.. Post back if you have experience in electronics and you wanna try it yourself..
Mar 26, 2008 | Liquid Video A170E101 Monitor
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E197FP LCD Monitor Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
