Question about Western Digital External USB 2.0 80 GB Hard Drive
Cannot Access my data, even if my laptop detects the drive when plugged
I cannot access my data , even if my laptop detects the drive. As soon i plug it in, it does the regular autorun for the drive and gives me option to begin with, but when i access any file on drive, it reacts as if the file does not exsist.but it lets me browse throught folders and sub folders. And after a while i cannot even see what files and folders i have. i have lot of data on my drive... is there a way i can fix this problem with out formatting ?
    New Friend:
  • 21 Answers
You can try some data recovery software. You can see
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Posted on Dec 05, 2012
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
If you can't access your files,data recovery software can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive to preview whether your files can be recovered. BTW, you can get it from
Data Recovery on Mac OS X
Data Recovery on Windows OS
Remember: Do not save your recovered data onto the same externalhard drive, otherwise the files you want to recover may be written over.
Posted on Jun 15, 2012
  • 233 Answers
I had a similar problem, I removed the drive and purchased a USB Harddrive enclosure, I got lucky that it has the old enclosure and not my drive.
hope this helps
Posted on Jan 08, 2008
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
Hi, my Immation Portable 160GB as soon as I plug it into my computer, the light is on, the HD seems to be working, but on my pc it doesnt even appear on MY COMPUTER the disk to open. I plug it and windows...
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 17, 2011 | Imation Apollo Portable - Hard drive - 160...
After not using my laptop for sometime,i can't have access to the O.S,how do i have access to it.i badly need to access my data
If the laptop cannot boot up then to retrieve your data then remove the hard drive from the laptop and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port. This computer will detect this as an external storage device. You can then click on this device and open the folders and files to copy and backup your data files.
Nov 10, 2010 | Dell Inspiron E1705 Notebook
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
The hard drive is not being detected on our laptop it turns on and everything but its not being detected what is the problem its not even a year old yet.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Oct 09, 2009 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
Acer Aspire T180 with Vista and Hard drive not accessible
external 3.5 hard drive caddy
put your drive in plug in and it appears as a drive
Jun 06, 2008 | Acer Aspire™ T180 PC Desktop
Western Digital External USB 2.0 80 GB Hard Drive Logo
125 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
