I have a top loading washing machine that no longer shuts the water off automatically when its filling up. whats going on? The water source to the washer has to be shut off because water will keep running into it and it overflows.
    Problem Solver:
  • 11 Answers
This is usually caused by sediments in your water supply getting into the fill valve, and preventing proper valve closure. My guess is the cold water supply is the culprit, as the sediments on the HOT supply generally settle in your water heater. The best solution is to replace the fill valve, as attempts at repairing the valve are generally futile. Replacement on most top loaders is fairly easy, the most difficult step is usually opening the unit to access the valve! Some are accessible at the rear of the machine.
Be sure that the filter screens are properly installed to prevent premature failure of your new valve assembly!
I hope this will solve your problem.
Sincerely, Bondo
Posted on Nov 12, 2009
Out of balance
Did your clutch pulley use the upper One-Way Bearing ring?
What are the first two digits of your Serial Number of the machine?
What is the history of the Clutch install? Did the unbalance issue continue right away with the new Clutch Install?
How much rust did you find on the Clutch Pulley and the Upper One-Way Roller clutches bearing ring if used? Any Pic’s of the old Clutch Pulley?
If you shut off the water source valves to the machine and release the top the washer so you can lift the washer top and observe the wash basket rotating CCW at 50 RPM during the water fill part of the wash cycle.
Start a quick wash cycle and lift the washer top to observe the wash basket rotation CCW. The wash Basket will rotate CCW at 50 RPM. You can go into Service Mode and observe on the LED console FAV6800A machine. Not sure about the FAV9800A LCD flavor of the machine.
Do the tumblers rotate slightly during the water fill part of the cycle?
The machine may error out with NF for No Fill don’t worry about that I just want to determine if the tumblers are rotating during the CCW/Spin direction of the wash basket. You may have to put some dry laundry in the wash basket to help with the observation.
Let me know what you see……..Rich
Jul 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water will not shut off when filling on wash cycle. Pressing OFF does not stop the filling. Only solution is shutting water OFF at wall source. Is this machine worth fixing? Are parts available?
The problem is the water inlet valve has failed. This is inexpensive and easy to replace. Here is your part # AP4026989 If you need help installing try this link http://appliancehelponline.com/topload.html
all parts come with installation instructions. You can also enter your model # for diagrams and illustrations
Jun 15, 2010 | Maytag LSE7806A Top Load Stacked...
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Only hot water will fill, cold water will not
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Roper washing machine hot water won't shut off
An obstruction in the hot water-inlet valve may mean that it's no longer able to shut off and should be replaced. Good luck !
Sep 11, 2007 | Washing Machines
Top loading automatic washing machine not filling
Check the filters on both sides of the inlet water line. Let me know with your results for further assistance if will be needed. Good luck!
Aug 31, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
