Question about Sony Dual Shock 3 Controller for PlayStation 3
Dualshock 3 select button acting like start button
    Filmmaker:
    Uploaded 5 video answers.
  • 99 Answers
This sounds like you may have gotten some debris or liquid inside the controller. Try taking the controller apart and cleaning it with isopropyl alcohol and a q-tip.
Posted on Nov 25, 2009
Polaroid dualshock probleme
turn off the ps3 plug control in via usb turn computer on with center control button
Nov 13, 2013 | Polaroid Pgps533blk Playstation 3...
When trying to play Resistance: Fall of Man, I get to the initial setup screen and it says press start to continue. When I press start nothing happens. I have waited long over the 45-50 second period. Any...
I had the same problem, believe it or not when I tried a different joystick (DG wireless lava glow) it worked. For some reason my original dualshock 3 joystick would recognize when I pressed the start button.
Nov 02, 2012 | Sony Resistance: Fall of Man
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
I dripped a bit of water on my dualshock 3 and its buttons started acting up. i left the pad for a while. when i press the ps button i get nothing and when i connect via usb the lights just flash. help...
Water on electronics is extremely problematic. In almost all cases, unless properly and promptly taken care of, the device is usually ruined. When you spilled the water on it and then pressed buttons, the electricity that is normally sent was intensified by having a conductive material present, and the internal components were probably fried. This is why the controller can't correctly interpret the buttons that you are pushing. The PS3 controller is problematic in that to turn off the controller, you actually have to press buttons. In the future, whenever you spill water on any electronic item, immediately turn it off and allow to air dry for at least 2 days before even attempting to turn it on again. Unfortunately, in this case, I think you are just out a controller.
May 12, 2011 | Sony PS3 Dualshock 3 Controller GamePad
Dual shock 2 wire digrem
The pinout is as follows when looking into the cable like this;
__________________
1 ' * * * ' * * * ' * * * ' 9
\_________________/
Pin Name Description
1 DATA Data
2 CMD Command
3 +7.6V
Dualshock and Dualshock 2 uses this for powering vibro-motors. Voltage on PS2 is 7.6V, however many sites says it's 9V. But it will work on 9V too.
4 GND Ground
5 VCC Vcc
6 ATT ATT select
7 CLK Clock
8 N/C Not connected
9 ACK Acknowledge
~KenjiFox
Jan 07, 2011 | Sony PS2 Dual Shock 2 Controller...
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Sony Dual Shock 3 Controller for PlayStation 3 Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
