Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I just got this hard drive and am trying to install it .but i sould not have to pay . if that is the case i will take it back and find some thing better i want installation instructions
    Master:
  • 969 Answers
Z3101
If you are having difficulties with installation the problems could be a number of things. Faulty Optical drive (CD or DVD) Faulty hard drive or a faulty recovery partition. The failed hard drive is most likely in your case. To test the hard drive you should get a HDD management suite from someone like Seagate. This will allow you to check the physical functioning of the drive and its ability to read and write.
Apr 30, 2013 | Computers & Internet
How do u use this thing? i found awhile back but dont know how to use it. its a hitachi deskstar hard drive. model number HDS721616PLAT80, P/N 0A32722
You can install this hard drive into an USB hard drive adapter case and use it as an external USB hard drive for back ups and file transfer from one computer to another.
Oct 26, 2012 | Fujitsu HITACHI DESKSTAR 7K160...
I have Optiplex GX520 desk top without a cd rom. What type do I need to install one in the com. or sould I get an external type? Also how much would either one cost?
It would be better to get an internal drive and get a DVD player/recorder you ,can find ione at Amozon.com and usually the are under 30 dollars Make sure you know what you need SATA or ATP
Aug 17, 2011 | Dell OptiPlex GX520 PC Desktop
My asus K601 just shut down and i have been trying to reboot it or format it and it gives me an error saying cant find hard drive
When you see this you either have a bad hard drive, or if you are real lucky its loose, or the drive controller on the main board is gone (not at a all lucky).
The first thing to check is to listen for the drive spinning up. You need to put your ear on the bottom of the case over the drive and then power it up. What you are listening for is the sound of just the drive. It should sould like a turbo spooling up. If there are any clunks or bearing noises then your drive needs to be replaced. Figure on $80-$100 for a new drive. Go as big as you can afford as its worth it. Replacement takes longer to explain than to do. You take the cover off then one or two hold down screws. Then the drive in its carrier comes out. Take the drive out of the carrier, put the new one in and put it back together.You will have to format and partition but that is all it takes.
It is very uncommon for the drive connector get loose enough to cause problems. Basically you take the drive out and put it back in and that is all it takes to fix it.
If the hard drive is actually good then the only thing left is the drive controller. To fix that means replacing the main board which can be up to a few hundred dollars. And the laptop needs to come right apart so there is a bit of labour involved. The total can be more than a new replacement laptop. This is rather uncommon but it happens.
The hard drive is the usual suspect. It spins up and down and is subject to damage if the laptop gets bumped or dropped. I'd start there
Nov 07, 2010 | ASUS Computers & Internet
I have U3 sandisk cruzer 8GB yesterday it was working fine, today when i plug in, it asking me to format it, how can i fix it or how can i recover my data in it
Problably you will loose your data if reformat. Search for Mini Tool and grab the freeware to try 1-recover your data and 2-one to format.
Oct 06, 2010 | Computers & Internet
Maxtor basics stopped working does not turn at all but has a blinking light - when I click on the drive letter in Windows it asks me to format the drive. Help!
It appears that this is a power related issue.
Pay close attention to the first link:
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=884
and this:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1010312.html
The same thing unfortunately happened to a WD drive I had and it was an internal power issue. I took the drive out of the case, not a hard task and can be done, installed in my desktop and, well, now I have an extra intenal drive.
Jul 09, 2009 | Computers & Internet
Maxtor 3200 - ASAP
It's ruined, and even more so now you opened it.
If there is important data on it then a data retreval service could try to recover the data for you by removing the platter (in a clean room) and placing it an special reader but at a price!
Oct 22, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Upgrade hd on laptopp
The easiest way is to remove the casing under your laptop and see what make your drive is, but any make of laptop hardrive sould be ok. Sometimes the hard drive may be held in a cradle so you will have to remove it if this is the case and use it with the new hard drive. A problem comes when you probably have the Acer backup/restore folder on another partition(which sometimes includes Windows, as you don't always get a hard windows cd rom),on your current hard drive, so make sure you have a Copy of Windows otherwise You'll have to purchase another Windows installation disc, or clone your drive with something like Norton Ghost.
Nov 24, 2006 | Acer Aspire 3000 Notebook
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
55 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
