Can you please tell me the Flow Rate for Raytheon Mod #UW125PVQV40001 we need it in order size a boiler properly, thank you
    Problem Solver:
  • 12 Answers
If you select a hot wash the tub will fill with hot water from your boiler only on main wash. See how many buckets of water that takes to fill to that level. Then depending on how many times you use the machine a day, that will answer your plumbers questions.
Posted on Nov 13, 2009
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
Apr 24, 2014 | DeLonghi Stiromeglio Compact PRO 300 Iron
Hi iv got 2 dirtblaster lance both doesn't work but does in friends whats the problem
those rely on "flow-rate". The oriface is sized for a certain flow-rate so it may be that your washer does not produce enough flow -- but your friend's washer does. Flow-rate is typically measured in GPM or LPM. With most of the commercial makes (brand), you can buy a rebuild kit and size it smaller than the original, causing it to match your pressure washer's flow-rate. To do this, however, you would need a vender to figure out which make it is -- then, if he knows the flow-rate, he can reference the orifice size and sell you the proper rebuild kit. You can expect those to cost between $20 and $40, generally.
Don
Feb 28, 2012 | Garden
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Britony 80 combi boiler G31 propane, gas flow rate =0.124877 cubic meters per hour, inlet pressure 37mbar, room sealed flu Manufactures recommended Co2 & NFGT unknown, cold water from hot tap when...
You gave a good description of the boiler--
now we need to hear the clues you have observed, as it fires (or fails to fire-- or what?)
Or as the water flow-- or doesn't flow?
As the cold water enters-- what does the flame do?
And does the flow rate reduce as the flow gets to the divert er valve?
How old is the boiler?-- and have we been using HARD water?
(Any water softener in the circuit to remove calcium and magnesium, etc.?)
Do you suspect a scaling problem in the interior parts?
If so-- can you circuit an acid thru the innards, to clean up the scale?
Please comment on what happens when water and gas flow-- so we can help you get to the next step.
Mack B
Jan 17, 2011 | Heating & Cooling
The hot water spout is not dispensing water properly. The flow rate is low. its not the spout itself, I've replaced it... The water line appears to be unobstructed... Any idea what could be blocking the...
Mineral build up, remove the top panel and clear hose to boiler, you will have to turn machine off and remove hose at boiler and use a small screwdriver to clear fitting on boiler.
Nov 24, 2010 | Bunn Dual TF DBC Coffee Maker
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
I have a type 100 12 course computer that has a low battery alarm as soon as the ''auto'' button is pressed I found the rectifier diode ''D19'' was bad I replaced it and the computer worked for 1 day then...
Contact Frank Zabroski SR of Audio-Tronics he may be able to help you get everything you need
Audio=Tronics
8566670616
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 15, 2009 | Raymarine RAYTHEON S2G Notebook
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Combi boiler wont re-pressurize when i turn the little valve under boiler it just seems to run and run and the pressure gauge dosent go up at all? there are no leeks. but a minute a go it went right up to...
the little valve is a one way type. this means the pressure should only flow one way. it's a good chance that the valve body is allowing the pressure to back flow. i would replace that valve. this should take care of it. please rate this thanks
Aug 29, 2008 | Water Heaters
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
