Question about Asrock P45XE Motherboard
Windows has stopped this device because it has reported problems. (Code 43) windows version is:windows 7 build 7100. so is it windows failure or hardware problem??? this is my second asrock(P45XE) motherboard... and i m not satisfy to this "behaviour",because i have buy new one!
    Scholar:
  • 40 Answers
Assuming that the "device" in question is a USB device, you should check that the USB port is not damaged AND free of any dirt or debris. Ditto for the device that will soon occupy the USB port.... Perhaps it is the cable that is the culprit??? More importantly, WHAT device has Windows stopped due to yada yada....??????
Posted on Nov 12, 2009
Windows has stopped this device because it has reported problems. (Code 43) epson printer CX9300F
Make sure you are using the correct driver for your operating system. You can download drivers for Windows 7 32-bit and 64-bit here:
Epson Stylus CX9300F Drivers Software
Note that this is a non-US-based website. Make sure that the language of your version of Windows 7 and the Epson driver you install are the same.
May 03, 2014 | Epson Stylus CX9300F Series
Panasonic kx f612 code 43 error
Windows has stopped this device because it has reported problems (Code 43).
Code 43 can be summarized in two words: driver problem.
I can't help you any more without knowing which Windows version you are using, but the Panasonic website is
http://panasonic.net/pcc/support/bfax/
Jan 28, 2014 | Computers & Internet
Windows error code 43
known problem, that might be fixed by a cold start. switch off your PC or laptop completely. even pull the power lead from the wall, (in laptop remove power supply and battery once switched off) wait a few minutes and power up and start your machine.
I hope this was helpful
Oct 31, 2013 | Computers & Internet
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Oct 05, 2013 | Nokia 6230i USB
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Device not detected
Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
Feb 17, 2012 | Gigabyte GE-S800A-D1 ODIN GT 800W POWER...
I have recently upgraded my operating system on my computer from XP to windows 7. since then my ATI X1650 PRO graphics card has been stopped by windows with the following message: "Windows has stopped...
go to device manager and click on display adapter then right click on ATI X1650 then run an update. It might be because the driver on your computer is not update with the driver that is not compatible with windows 7. Hope this would help. Thanks.
May 30, 2011 | ATI RADEON X1650 Graphic Card
I have windows 7 in my dell vostro 1014 laptop.my bluetooth is not working.in device manager it shows windows has stopped this device because it has reported problem code :43
Code 43 appears when one of the drivers controlling the device notified the operating system that the device failed in some manner. This is a sign of hardware failure - the BT chip has failed.
Try a hard reboot of the device: disable it from Device Manager, go into the BIOS and try to disable it from there, then reboot one more time, shut down the pc and remove the battery for an hour , reboot then reenable it from the BIOS , reboot and reenable it from Device Manger- if you get the same error then its dead - disable it permanently and buy and install a BT USB stick.
Apr 25, 2011 | Computers & Internet
Asrock P45XE Motherboard Logo
244 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
