Question about Sony Playstation 3 (PS3) Console
Xmb menu hellow. i have a ps3 and i decided to swith to the hdmi cord. my problem is that my xmb screen is blank but i can hear movement on the screen when i use my controller and scroll thru the menu. but the picture is still blank. however i get the normal screen when the game moves on to the loaded game. i need to be able to see what im doing in the xmb screen. what can i do. i can no longer see the xmb screen, i can only hear when im moving around with the controller. the game mode works just fine n shows excellent now that i have switched to the hdmi cord.
  • 182 Answers
When you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Posted on Jan 08, 2008
When I'm told the system was not turned off correctly press ok then the screen stays blank
You corrupted your settings. Turn on the Ps3 let it power cycle, once you get to the blank screen hold down the power button until it beeps 3 times (about 25 secs) Your ps3 will shut off( note: if you have HDMI only, plug in your RCA connections as this will reset your ps3 display to analog) once you are back at xmb, plug in your HDMI and go to display settings and select HDMI. Always let your PS3 do its thing before shutting it down, its equivalent to unplugging your computer instead of logging off correctly.
Jul 06, 2012 | Sony Playstation 3 (PS3) Console
Hi,i was on the main menu of black ops,when from nowhere this white screen appears.it was there for 30 min,thought it would go away then i swithed of the ps3,i switched it on again,but there was no...
The GPU overheated. Most likely fried, but you can try to let it sit for a few hours and see if it will boot again.
On an outside chance, you may try resetting the video options when you boot up the system. To do this, press the power button until it beeps once a second time. This will reset the video options and restore functionality if the problem is software related.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the screen loads but the xmb does not what can i do to fix this.
Are you using an HDMI cable? Or did you use that before but are now using a regular cable?
-Hold the power button until you hear the beeps; the video settings will have reset themselves.
-Plug in the regular cables (yellow, white, red)
-If you can see the image, then stop right here
-If you want to use an HDMI cable, then follow the above steps, but...
-Go to Settings-->Display Settings-->and change it to HDMI or whatever cord you are using
-Restart the PS3, using the cable you set it to use.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
I had my ps3 hooked up through a HDMI plug and I swithed tv's, now I have no video with the HDMI plug or the red, white, and yellow. Please help!
Hi, The settings on the PS3 are sending the video signal throught the hdmi port. Either go through the XMB via sys settings, display settings,or if you only have a low def tv then hold the power for 5 seconds (when you turn it on i belive) and it resets it. You may have to adjust the audio settings at the same time, because if you pressed yes when the HDMI was first connected, you agreed to send the audio signal via hdmi as well.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
My ps3 turns on but nothing appears on the screen what should i do? i have all the cords plugged in
Your question is lacking a little information, but I assume you are using a HDMI cable. First you need to turn the PS3 on by the switch on the PS3. Then press and hold the On/Off button on the PS3, keeping it pressed until you here a clear beep and then a couple of seconds after you should hear a second beep. Once you hear the second beep take your finger off the button. Now as long as you are on the correct HDMI channel the rest should be on the screen for you to complete.
Please Note - If you have it working on a particular TV, then decide to unplug the PS3 and put it on another TV, there is a very good chance it will be blank again. This is normal because each TV has different setting, pixels, size, etc, and the HDMI has to be set to each individual TV. Once you get use to the settings. It takes no more than 1 minute to do.
Cheers, and hopefully this will solve your problem.
Feb 09, 2010 | Sony Playstation 3 (PS3) Console
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
I was switching my PS3 from using the hdmi cord to using the regular cord so i could use it on another tv. when i switched the cord settings it had to switch the tv settings on the PS3 from 1080p to like...
so u must go n plug the hdmi cable in a tv dat support an hdmi feature so u can be able to fix the problem from the menu.....if it's not lkike that i think u can use the AV cable on a normal TV ....so u can fix it as well
Aug 19, 2008 | Video Game Consoles & Games
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 startup software won't load correctly
turn on ps3 leave on stand by (red light), hold eject button and power button until you hear beeps and a message appears. connect controller and press ps button. system restore screen should appear, select restart system and from there it should restore everything back to normal. This worked for me, for clear instruction go to http://blogallalong.com/2008/12/05/ps3-green-light-on-and-system-wont-start/#comment-31058
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
