Question about Electrolux Washing Machines
My softner compartment is not emptying. - Electrolux Washing Machines
    Problem Solver:
  • 11 Answers
I know this may sound silly, but I have seen this problem solved on many occasions by cleaning the filter screen(s) in your cold water supply hose!
This is because the softener dispenser must fill with cold water (on top of your softener liquid) in order to start the siphoning off of the softener. If the cold water supply is restricted, the dispenser will not receive enough water begin the siphon effect.
Now before you tear things apart, try this test...
Begin a wash cycle by filling with HOT water, and observe (listen to) how fast the tub is filling for a few seconds... Now change the wash temperature to COLD, and notice the difference in water flow. If you detect a noticeable decrease in water flow... Clean the cold water hose screens!
How? Unplug the unit! Turn the cold water valve off, and remove the hose. (If you did the test above, you will easily feel which hose is the cold one.) Use a small brush and a squirt bottle to clear the screen inside the inlet to the washer, and also check the end of the hose where it attaches to the plumbing... some guys put a screen at both ends of the hose. Put it back together, turn the water on and CHECK for leaks.
Another possibility could be a build-up of softener liquid in the compartment drain hose. This can generally be solved by carefully pouring a teapot full of near boiling water in the compartment to flush the hose. Expect to see the compartment nearly full before it starts to drain... it has to fill somewhat before the siphon effect starts the flow of the drain hose.
I hope this helps you!
Bondo
Posted on Nov 12, 2009
Not emptying conditioner compartment conditioner
This video will show you how to keep your soap draw clear and how to service the parts
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2011 | Hotpoint Aquarius WD63 Front Load...
Fabric conditioner compartment will not empty when in cycle
FJS1225W Front Load Washer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
May 17, 2010 | Zanussi FJS1225W Front Load Washer
Water is backing up in the fabric softner dispenser? After every wash I have to empty the fabric softner dispenser because it is full of water
Bosch Nexxt Premium WFMC6400UC Front Load Washer
This video will show you how to keep yoursoap draw clear and how to service the parts
a 4 THUMBS rating is appreciated for answering your FREE question..
Dec 03, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
Water doesn't empty out of the softener compartment.
clean the syphone cap it is more than likly clogged with softner. some water being left in there is normal though.
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Water left in bleach and fabric softner after running load
You must take out the compartment and empty it out before adding any bleach the next time, there is a type of button way in the back that you press down on pull out the entire door and empty the water for the next washing. You must press down very hard the entire door does come out check out your book for instructions it is way in the back on the left hand side. This happens to mine once in a while not all the time.
May 05, 2009 | LG WM1812C Front Load Washer
How to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Jan 03, 2009 | Dishwashers
Washing machine
hi if your softner dispensor is a removable compartment from the soap powder drawer ? then remove the dispensor and you will see the pipe with cap on top at rear ? pull this pipe off and ensure it is not blocked and that the cap is a firm fit on top? then ensure the short pipe that is part of dispensor tub is clear reassemble and refit try again ? these softner dispensor work by syphon effect IE when you top up to recommended level with softner in dispensor ? it remains untill wash is at softner rinse cycle then when water is entered into dispensor of softner and the level is raised to above the short pipe within compartment and the outer pipe with top on ? the syphon effect takes place and the softner+waterlevel is is syphoned int machine and dispensor is empty?? i hope you understand ? it is simple and works if you think of a toilet cistern how it syphons water for flush it is the same principle hope this helps
Oct 30, 2008 | LG Washing Machines
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
311 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
