Question about Maxell MF2-HD-IBM-10MX (mf2-hd-ibm-10mx) Floppy Disk Storage Media
Access on maxell mf2dd
Is there any special software needed to view a maxell mf2dd on a mac?
I have a disc with some records on but i cannot get it to open all i get are line after line of hash key signs
Do you know what the type of files are that are on the disk? They could be .DOC or something like that or they could be a special file that needs medical software to open. If you put the cd in the computer and you click on the drive and it opens the directory to view the files, can you tell us what the file type is?
Aug 02, 2014 | Maxell CDRW Discs 700MB80min 4x Silver...
Tip
Tips: Enjoy PDF ebooks on iPad, iPhone for (Mac/Windows) users
eBook Readers make reading experience more pleasant. Hold eBook device like a book, for it carries as many of desirable content at your fingertips. In addition, it can also allow you to take notes, highlight message and easily access to the passages you need.
Both PDF and ePub are two of the most popular eBooks formats. Each of them has its own characteristics. Such as eBooks in PDF format can support Book-marking, however, ePub eBooks can't do that. ePub-formatted eBooks can be optimally viewed by the eBook devices, for ePub is specially designed for reflowable content. Whereas, the PDF format doesn't have the feature. Different eBooks applications have their preferred eBook format. For example, Apple iBooks app uses ePub format as eBook format.
PDF to ePub Converter is specially designed for eBook enthusiasts to convert PDF to ePub for perfect compatibility with their eBook devices, such as iPad, iPhone 4, iPod Touch, etc.
For Windows OS: PDF to EPUB Converter
Detailed guide: How to convert PDF to ePub, PDF to iPad, PDF to iPhone 4, iTouch, etc on Windows?
For Mac OS: PDF to EPUB Converter for Mac
Full tutorial: How to convert PDF to ePub for iPad, iPhone, iTouch with Mac PDF to ePub Converter?
on Aug 17, 2010 | Computers & Internet
Maxell genpro software reinstall
you may find it in the manufacturers website
Jul 18, 2013 | Maxell 500gb Genpro External 25inch With...
Problem with internet connection
By "USB wireless internet" I assume you are referring to a communication card from a cellular telephone carrier.
I also assume that despite the fact that you have singled out Safari, in reality you will find cannot access the internet at all through this device, e.g., sending and receiving mail through Apple Mail, using iChat, using Software Update, etc. I say this because when Safari refuses to access the internet through a particular device, it's very rare that the problem turns out to be peculiar only to Safari. (To answer your original question, no, no special settings are needed.)
Many of these cellular internet cards come with "install me first" software for the Mac that is written badly and doesn't work on the most current versions of the Mac OS. Your first step (assuming you have another working route to the internet) is to visit your provider's website and download the current version of his Mac connection software (which will almost always NOT be the version you got in your product box). Install and run it exactly according to the instructions (they are often so fragile that any variation at all will break them), and then try again.
May 15, 2010 | Apple MacBook Pro Notebook
Its not reading Maxell writeable DVD's
There is software "inside" the DVD-writer.
It is called "firmware".
The firmware reads the "label" off each disk,
to determine capacity, maximum recording-speed, and such parameters.
So, you need to access http://support.hp.com and search for updated firmware for your HP device, because the current firmware is _not_ recognizing the label on that one specific brand of "blank" media.
Updating the firmware will allow the recognition.
Apr 07, 2010 | HP dvd640e DVD RW Dual Layer Burner
I'm not able to find a manual for the Creative Muvo T 200 MP3.
Unfortunately, you won't be able to view the manual on your Mac without installing 3rd-party software.
You'll need to find a CHM viewer for your Mac. I can't guarantee this particular program will open the manual you downloaded from Creative, but there's a good chance it might.
Go here and scroll down to the xCHM for Mac OS folder. Download and install the latest version of the software. From that point, you can try to open it using the xCHM program.
If that doesn't work, you'll have to try to obtain access to a Windows XP computer and use the following instructions.
For viewing the guide to the Muvo T200 on a Windows XP machine, go to this page. Under "Getting Started," click on "Quick Start User Guide."
Click on "Download." There will be an "Agree" button. RIGHT-CLICK on that button, so that you can save the file (it is a file with a .CHM extension) to your computer. (Opening it at this point won't work).
The instructions on the site explain how to open the file. Here they are, for your convenience:
...follow these steps to view its contents successfully:
  • Save the manual on your computer.
  • Right-click the manual and select Properties.
  • Select the General tab, click the Unblock button, and then click OK.
The manual should display correctly when you open the file again.
Once I followed those instructions (going to the properties of the downloaded .CHM file and clicking on Unblock then APPLY), I was able to open and read the file in its entirety (meaning the links/chapters within the help file worked properly.) Try it a second time in case the file doesn't show the correct info the first time (it's what I had to do).
Here's the text from the first paragraph of the "How to use this manual" chapter that is beneath "Creative MuVo T200 User's Guide:"
"This document has been designed to provide you with complete product knowledge. You can resize the document window, print this document, access linked web sites and get information from specially prepared graphics."
Good Luck!
Feb 09, 2010 | Audio Players & Recorders
Recover data from an external hard drive that doesn't work
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Dec 30, 2009 | Computers & Internet
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Apple I Mac special edition graphite-- how do i open casing to gain access to hard drive
go to http://www.faqintosh.com/risorse/en/guides/hw/imac/imacg3dvhd/
and follow the instructions on it. It should be similar to the older imac g3
Oct 13, 2009 | Apple iMac Special Edition Graphite Mac...
Downloading videos to imovie on a Mac
This is what the Sanyo CG9 Users Manual has to say about viewing videos taken with the camera:
"About video clip files recorded with this camera
You can use Apple’s QuickTime to play back video clips on a computer.
Playback may be possible using other software that supports the ISO
standard MPEG-4 AVC/H.264 (AAC audio)."
Apple Quicktime downloads are available here.
Jan 24, 2009 | Sanyo Xacti Digital Camcorder
Maxell MF2-HD-IBM-10MX (mf2-hd-ibm-10mx) Floppy Disk Storage Media Logo
190 people viewed this question
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
