Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Water heater not working. shows c2 than 11. any suggestion?
  • 244 Answers
First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board . You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. All that you need is a long phillips screw drive and a drill because its about 25 screws the burner assembly has 2 screws all in the back, underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Good Luck
Posted on Nov 17, 2009
    Problem Solver:
  • 7 Answers
Actually, to get to the back two flame rods, you have to remove the burner assembly, which means remove the pc board (connectors only go back on the correct slot), remove the upper gas lines and loosen the lower gas lines. You can get the engineering manual from the Paloma site, which details major component removal. I sanded the flame rods and igniters and brushed the burner with a stiff paintbrush. When reassembled, it worked like a champ and better than it had for a long time.
Posted on Apr 11, 2013
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
http://waterheatertimer.org/Replace-anode-rod.html
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
Bosch 250 sx ng tankless water heater showing error code. checked fuses and they are fine. tried resetting many times still not working
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Best place to start is troubleshoot section in manual. Page 24
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
Problems range from air supply, gas supply, venting, part failure or combination of listed things.
Don't forget, tankless require yearly maintenance, outlined in manual, and cannot be exposed to more than 11 grains hardness in water, and should be de-limed each year.
All costs are energy.
I suggest reading entire manual several times, so you are pro about your tankless water heater.
Even with this knowledge, trained service technician will have to be consulted
some day, and tankless should never be installed if factory trained technician not available in area.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
Install tank type water heater that can be put online when Bosch is not working
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Mar 04, 2011 | Bosch & Tankless LP Hot Water Heater
Tankless water heater water will not come out hot enough
1) Read your manual
2) De-lime unit on yearly basis:
Search google and Utube for 'de-lime tankless'
They make special fittings that permanently attach to water ports so you can delime each year.
Research shows that reqular de-liming will not restore tankless efficiency.
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
3) Typical manual shows temp information on page 22-23. Search pdf for 'temp'
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
4) Read maintenance steps shown in manual
The word maintenance appears throughout the manual
5) Search fixya questions on tankless to glean information about your unit:
Older answers have more responses, and each seems varied as techniques succeed for one person but not another.
The quantity of unanswered questions and vague answers reveals why Rheem suggests qualified technician be added to your rolodex-wallet
http://www.fixya.com/tags/rtg_74pvn
6) Other useful links for tankless owners:
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Mar 04, 2011 | Rheem Tankless Hot Water Heater...
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 12, 2011 | Reliance Water Heaters
21vp50-1 rheem water heater, the ignitor is not working
1) Rheem does not show that exact model number, since they list current products only.
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters
2) Rheem serial number shows year of manufacture on second 2 digits. So C06 was made in 2006.
Today's manual might not have troubleshoot steps that match older product.
3) 21vp50 is 50 gallon power vent water heater.
Open following link to identify product.
New models have Honeywell electronic gas valve with LCD flashing error codes.
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
http://waterheatertimer.org/gas-water-heater-timers.html#Rheem
4) Sample manual for newer power vent models shows error codes and troubleshoot steps:
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
5) Earlier Fixya answer suggests where to buy ignitor for 21vp50:
PART #HSI51409A
http://www.fixya.com/support/t3641891-rheem_21vp50_1_igniter_stopped
6) Your manual should show troubleshoot steps and expanded parts list.
Always save manuals like gold, and save searching later for a manual at Fixya.
If we can't find the manual, then our answers are limited to suggestions and guesses, since we're not on-site and can't perform troubleshoot steps for you.
7) Post your question on professional water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
8) Call Rheem and they can possibly suggest which local service technician will work on that model:
2600 Gunter Park Drive East
Montgomery, Alabama 36109-1413
Phone: 1-800-432-8373.
9) Call a local plumber.
10) Install inexpensive home-center brand gas water heater yourself:
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 03, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Once I switched the power to the hot water heater off while I was shutting the power off to document all the outlets and fixtures around my house. After I did this the HW heater stopped making hot water. I...
Sounds like a tripped reset button:
Photo below shows typical generic upper thermostat.
Open top cover on water heater, and push in red reset button.
Power is live on the terminals, so use wood stick and push reset inward very hard.
Put insulation and covers back over thermostat when finished to avoid cool air from influencing thermostat.
Reset as many times as you want, no harm is being done to heater.
You probably have a bad thermostat.
I suggest replacing both upper and lower thermostats for $28:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Ordinary tank-type electric water heater is fully repairable by homeowner without needing service technician. Use simple tools and generic parts from hardware-store.
Get started with link above. There are more links that show on same page, and you can read those if needed or whenever you want to work on water heater.
Jan 25, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We have a 501 in our office and we have no hot water. I have checked the breakers and I don't know what to do from there. Any suggestions?
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Jan 12, 2011 | RELIANCE ELECTRIC WATER HEATER
Water may stay hot for 5 minutes then gets cold. water heater often blows breaker or pop out switch.
I suggest taking 30 minutes and testing water heater parts.
Right away we know 2 things:
-Electricity to heater is good.
-Upper element is receiving power because you have some hot water. If upper element was burned out, you would have no hot water.
That leaves 5 suspects:
Upper thermostat.
Lower thermostat.
Loose or shorted wire.
Upper element shorted to ground near center of element.
Lower element shorted or damaged in some manner.
Buy $10 milti-meter from Home Center or hardware
When test calls for testing voltage, rotate multimeter dial to 240-250-277 VAC.
When test calls for testing elements or continuity, rotate multimeter dial to Ohms.
Take 30 minutes and go down page.
Test will identify problem(s) and show how to fix it yourself.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Add a comment for more free assistance.
For a price, fixya expert speaks to you via phone while you work on water heater.
Jan 01, 2011 | RELIANCE ELECTRIC WATER HEATER
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
315 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
