Question about Dell 1720dn Laser Printer
Dell 1720 printer prints crooked i.e. left margin is not parallel to edge of paper
    Problem Solver:
  • 13 Answers
Most likely you have a bad pick-up roller. it is inside the printer directly above the paper tray. this is one reason the paper would pull in an angle.
Posted on Nov 14, 2009
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
I cannot get printer to print documents with equal margins.
Guess you are not using the same page size as the one you've got configured in your computer for printer. ie: you are using Letter and printer is configured to A4
Jul 18, 2015 | Dell Office Equipment & Supplies
How do I Adjust the Printer Margins for Dell 1720 I am printing on insurance forms and the print is too high and to the right
I have found a good manual that can help you easily with the help of pictures.
Click on the link below to access it :
ftp://ftp.lexmark.com/depot/Dell/Dell_1720_Depot_rev061807.pdf
In case of further help let me know
Mar 21, 2010 | Dell Laser 1720 Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
I want to print a brochure in word or psd and how I can print edge to edge, borderless.
Within MS Word, minimize the "left-margin" and "right-margin" settings/
Use "printer setup" to minimize the margins.
Oct 31, 2009 | Microsoft Office Word 2007 Full Version...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Pages coming out crooked
Try to feed the paper on the tray properly..
May 18, 2009 | Dell Laser 1720 Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Print is not straight
It sounds like the paper is being pulled into the printer at a crooked angle. Check that the guides in the paper supply tray are adjusted correctly to the paper width and are tight against the stack of paper. Alternatively one of the rubber pinch rollers that pull the paper though is slipping or worn smooth. Regards
Sep 24, 2007 | HP DeskJet 930c InkJet Printer
Dell 1720dn Laser Printer Logo
540 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
