Question about Whirlpool Electronic Window Air Conditioner ACQ158XR
Air works great but my heater stopped heating in my window unit can you replace the heater part
    Scholar:
  • 111 Answers
Yes Heaters can be replaced in window units.
You can find a local store near you for the repair here.
http://shared.whirlpoolcorp.com/sharedservices/dealerlocator/dealer_search.jsp?siteCd=WHRCOM&dcsref=http://whirlpool.com/home.jsp
Good Luck!
Posted on Nov 13, 2009
2000 ford taurus heater not working. What can be wrong?
It sounds very much like the heater control door (inside the heater box) is sticking in one position or the other. It's intended to direct air through either the AC's evaporator or the heater core, depending upon whether you want heat or cooling.
Assuming (highly likely) that the control door is vacuum-operated, you may have a vacuum leak anywhere from the engine to the heater box inside the passenger compartment, via the heater control unit.
Nov 18, 2014 | 2000 Ford Taurus
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
The heater won't heat in my window unit.
Hello Jim Hyde - Try pressing the reset button on the plug, if you haven't so already. If the unit continues to not heat up, contact a professional that works with your manufacturer to move forward accurately. Keep in mind that for some air conditioners the heating option is simply a supplement to help heat up a room but in most cases it will not completely heat up the entire room.
Oct 09, 2012 | Frigidaire FAC126P1 wall/window Air...
Heating stops working all of a sudden
what kind of heater is this a household unit or a window unit... could be numerous problems if the heat starts to work is the fan continuing to run? also may want to check for obstructions such as a dirty coil which would make the unit get to hot and a limit is shutting unit off... what kind of unit and brand? i work on heating /air and all major appliances for over 17 years let me know
Dec 31, 2010 | Heating & Cooling
Cadet C151 heater not producing warm air.
take your tstat off jump out the wires red green white together. if it works like that then your thermostat is bad. if it doesnt then it is in the unit.
Mar 24, 2010 | Cadet Manufacturing Com-Pak Plus C151...
This dryer worked great until it stopped heating
There are four main components for the heater to operate control thermostat, igniter, flame sensor, and gas valve coils if one of this is not working the unit will never heat. That if is gas. If is electric control thermostat most likely needs to be replaced
Feb 20, 2010 | KitchenAid Dryers
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Whirlpool Electronic Window Air Conditioner ACQ158XR Logo
105 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
