Question about Dell Inspiron 2200 Notebook
Corrupt & Locked Bios
My daughter got a root virus that corrupted and locked her bios. It will not recognize her hard drive or her optical drive. Therefore I can not boot Windows or configure the boot sequence. I removed the cmos battery over night and reinstalled it with no success. I'm told its possible to flash the bios without going into Windows, but I'm not sure how yet. Could someone give me a step by step? I've already downloaded the bios file on another computer
Will flashing my bios remove a malicious bios password? If not does anyone have knowlege of a place to get backdoor bios passwords for free or very cheap for out of warranty machines?
Dell Inspiron 2200 Laptop, Service Tag#: JDJVN81-595B
  • 2,229 Answers
When you flash the bios (normally from a floppy drive) it should overwrite anything that is there.
In this case you must boot from the floppy. Unfortunately, with a laptop you don't have that option.
I suggest you put the bios flashing utility that you probably downloaded with your bios update file on a flash drive. I think your laptop has the ability to boot from that.
Anyway, on startup, press F12 until you get the boot options and try that.
I take it that you know the support site URL, but just in case, it's support.dell.com
Posted on Nov 12, 2009
Testimonial: "Thanks much for the quick answer! I wasn't sure since Dell keeps laptop bios passwords on a separate chip from the bios itself. "
L410
Step 1:
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot.
Feb 27, 2013 | Acer Veriton Computers & Internet
GMA 4082n device driver not working properly code 39
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
Bootmgr is missing
Step 1:
Feb 15, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
No boot device available dell optiplex 170l series
Go to the bios to verify that the computer is recognizing the hard drive and that the hard drive is is listed in the boot sequence. If this is all good your hard drive may have been formatted or erased or the boot record is corrupt and unreadable to the bios. I had a similar problem. reloaded windows and all was good.
Feb 12, 2013 | Dell OptiPlex 170L PC Desktop
Cd no boot record
Hope this helps.
Nov 19, 2012 | Computers & Internet
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
Emachines D4362 starts only after many button pushes
Sounds like you might have corrupt window system files or the machine might not be recognizing the hard drive.
Press the DEL button to go into the BIOS. Go to the section that shows you the hard drive. If it doesn't show you a hard drive model and shows none then your hard drive is bad and would need to be replaced. If your hard drive is recognized in the BIOS then you'll need to try and reinstall windows. If you can't get windows reinstalled then the hard drive is bad at that point as well.
Jan 18, 2012 | E-Machines eMachines Desktop PC
My acer 2420 laptop crashed due to virus. i have removed hard drive and all the files i require have been copied. to continue i need password to reset computer
If you have a virus that still persists, it means the virus has corrupted your bios chip. This requires that the laptop be taken apart and the chip reset or replaced. Or simply reload your old O/S and start afresh if you know that the bios is not corrupt.
Dec 15, 2009 | Acer Computers & Internet
DRivers appear to be corrupted or missing
Hardly impossible for disc drive's drivers have become corrupted unless you have had a bad attack of Viruses. Check the power and data cable. If needed use a new IDE cable. Clean the contact points of the RAM. Then try to enter the BIOS to see if it has recognized the drive! Physically lay your fingertips on that drive to determine any vibrations which is a indication that power is reaching the device. Then try using this sane drive on another PC to check if its working properly or not. Finally lok for the latest driver depending upon the model & make of your Firmware.....................sodeep
May 02, 2009 | Computers & Internet
Hard drive stops booting
Hi, If your computer stops booting from the hard drive and is asking for a boot disk, then: 1. The motherboard/PC is no longer recognizing the hard disk; 1.1 Go to your CMOS/BIOS setup and manually detect the hard disk, save & exit. 2. The CMOS/BIOS is set to boot from other devices such as CD, FDD or USB but not from the HD. If after configuring the CMOS/BIOS and the hard disk is not recognized, then it is probably defective and therefore need to be replaced. If the hard disk is recognized but will not boot, then some files of your OS needed to boot are missing, corrupt or overwritten. You would need to re-install your OS and opt for a "repair". Hope this be of some help/idea. Post back how things stand or should you need additional information. good luck and kind regards.
Oct 01, 2007 | Fantom Drives EXT HD 80GB| MTT80 RTL Hard...
Dell Inspiron 2200 Notebook Logo
270 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
