Goodman heat pump the fan runs but blows the 3amp fuse
Hello all I have a goodman heat pump the fan runs but when to trun to heat or cool the 3 amp fuse blows what could it be ???????
    President:
  • 1,515 Answers
The 3 amp fuse is for you're control voltage only, which is 24volts,ac. Something in the control side of your unit has a direct short in it. Since I am not on site to help you find out what part is at fault, I will give you some things to check out.You say you're indoor fan runs. I can only assume when you put the thermostat fan to on and not auto. Since this is a heat-pump, and not a gas fired unit, you will have a few less things that are 24volts.You say it blows the fuse on both heat and cool. You or someone that may give you a hand needs to do a process of elimination. What you will need to do, is to check all of the 24v. components to see which is at fault. The 24volts via relays and coils are what controls the motors, compressor, ect. We know that the indoor fan is good. I would be looking at the contacter coil first, even though the thermostat is 24volts. Since the contacter controls the condenser fan motor and compressor, my guess would be the coil on your contactor is shorted. I am not sure if you're heat-pump is a package unit or a split? Either way, you need to open up the control section of the compressor section which on a split its the outdoor unit. On a package unit, its where the main power enters. That would be on what ever kind of Goodman you may have, the 220volts come in and each of the 2 hot wires connect to the bottom of the contactor.What to do 1st.What ever it is, a split or a pack unit, turn off the main power to unit, split, outdoor unit, pack, whole unit.Even if this is a split system, when you turn the power off to the outdoor unit, you will still have 24volts to it when you turn the stat on.The 24 volts comes from the fan center on the indoor unit. With all of the power off, look at the contactor. On each side you will see 2 wires to a copper coil. Pull off these 2 wires, and dont let them touch anything even though they are dead.Turn power back on and check the 3 amp fuse. It should be fine. Now, with the power turned back on, touch these 2 wires back to the coil.This should blow the fuse. If it does, that contactor needs to be replaced.I know this is a lot to check, but I am sure the contactor coil is shorted. You will have to buy one from a retail appliance store. Every wire must be put back in its original place. If you don't think you can test this, I would advise calling someone out. I know this is a long solution, but i am sure that is the problem. Let me know please. Good Luck,
Shastalaker7
Ps an electrical meter would be of a lot of use to you. One more thing, if the copper coil on the contacter is burned and black, just turn off all power and replace it. I am certain this is your fault.
Posted on Nov 12, 2009
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 14, 2017 | Goodman GMS90703BXA Heater
Central air blows 3amp fuse
Hello, check the thermostat wiring between the indoor unit and outiside unit and make sure it is secure. Also check the contactor coil on the outside unit and make sure none of the wires are loose and touching metal. You csn also unhook the wires and put them back one at a time and see which one blows the fuse.
Jul 10, 2012 | Goodman Heating & Cooling
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
On My goodman heat pump, It had blown the transformer, I installed a 3amp fuse and when engaged into cool mode blows the fuse. I have narrowed it down to the yellow wire in the heat pump that goes to the...
That low pressure switch is isolated so that would not be the issue. The defrost board is the most likely culprit but you did not post the model number to tell more
Jan 31, 2018 | Goodman Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
738 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
