Thermal fault message
I have a dell gtx270 that i recently retrieved from storage after about a year.Before storage i kept getting a thermal fault upon startup.I had to try restart several times and finally it would stay on.I found no visual problems and no heating problem inside the case before trying to restart.the problem of course is still happening but wondered if i could get some help on this matter.What does this message mean exactly and what do i need to repair or replace to correct this problem? all help appreciated..thnks
  • 54 Answers
Check for bad capacitors on the motherboard. The GX270 boards seem to have issues with this. See if the caps have a bulged X on the top and are not flat on the bottom.
Check out badcaps.net for help in determining if they are bad.
Also one other thing to check. Look at the North-bridge heatsink and see if it has a Z shaped wire running across it. On some Dell machines instead of the Z shaped wire there will be two U shaped wires running across the heatsink. Whether it is one Z shaped wire or two U shaped wires the ends of the wires will be connected to "eyes" on the motherboard.
These wires are part of the temperature sensing circuit. If one of the "eyes" connected to the motherboard is broken off you will get an overheating error.thermal fault message - 43b2b03.png
Posted on Nov 12, 2009
Dell Dimensions 9200, Desktop. Been in storage. Trying to open it, message says, 'in Save mode' tried the tips advertised to no avail
If there is space in another computer you have. just take out the hard drive from the Dell and put it in the other computer. It will have a new drive letter and you'll be able to retrieve more than just pictures from it.
May 28, 2016 | Dell Dimension 9200 PC Desktop
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
I have a Dell Dimension 24000 that has been in storage for a year. I recently tried to boot it up so I could find a couple of files. It starts booting up; windows logo appears and shows things are loading...
try starting in safe mode.
when you power on the PC, start tapping the F8 key on your keyboard.
this will give you the option to start in safe mode and can possibly let you find out why you cannot start up.
if it does start this way, you should at least be able to retrieve the files you were looking for.
Aug 06, 2010 | Dell Dimension 2400 PC Desktop
Message Archive
you cannot retrieve message archive from one pc to another. i suggest you just copy and post those threads to a different storage.
Apr 08, 2010 | Yahoo Messenger
Erased messages - digital recovery?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 17, 2008 | Uniden Cordless Phone
Taylor Lithium Scale Model 7000
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Oct 29, 2008 | Taylor Chrome & Glass Lithium Digital...
Can i retrieve deleted text messages from the sim card of a sanyo scp-7050
Thanks
Oct 07, 2008 | Sanyo SCP-7050 Cellular Phone
Memory full
1. Fax Storage may be set to On. When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions. The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, Fax Storage should be set to Off. Verify Fax Storage is set to Off by doing the following:
a. Press FUNCTION, 8 (Remote Fax Opt), then 2 (Fax Storage).
b. Check the setting. The display will read On or Off.
c. If the setting is On, press the left or right navigation key (arrows) until the display reads Off.
d. Press SET and then STOP/EXIT.
e. If you have faxes stored in the memory, you will receive a message that reads Erase all fax 1. Yes 2. No. This means you have faxes saved in the memory. If you do not want to reprint the saved faxes, press 1 (Yes) and then STOP/EXIT. After pressing 1 (Yes), all fax data is erased and Fax Storage is turned off.
Hope this helps!
May 20, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Windows Media Files
get a new one been there done all of that
Sep 14, 2005 | Dell Axim X50 Pocket PC
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
