Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer has a f1 error and I need to know what part I need to order?
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
I own a whirlpool washer model WTW6300SW Cabrio and I am getting an error code F1 and need to know what to do?
The F1 error means that the control board isn't communicating with the rest of the washer. Try unplugging the washer (or flipping off the circuit breaker) for at least 15 minutes to reset the unit.
If the error persists, you probably need the control board replaced. Appliance Parts Pro has the control board here: http://www.appliancepartspros.com/whirlpool-elecronic-control-board-w10189966-ap4360738.html . When you pull the control board, check the wiring to the other parts of the washer.
Of course, if your washer is under warranty, contact Whirlpool. I hope this helps.
Nov 21, 2014 | Whirlpool Washing Machines
F1 error code
Call Whirlpool at 800-688-9900.
Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
They will send someone out to replace the controller board for free!
If not, here is a link to the control board you need.
Oct 16, 2012 | Maytag Bravos Top Load Washer
What does F1 error mean?
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
Call Whirlpool or a repair center. The number for Whiripool is 1-800-253-1301
Nov 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does code f1 mean
Hello
Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I get an error code of "F1" when the washer first starts.
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Jul 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on cabrio washing machine
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
  • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
  • I'll let you all know how it goes after the repair..
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on Kenmore Oasis HE Quietpak 9
question is not is it repairable but is it under warranty ..most likely bad control bd under console
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
