Question about Cell Phones
Nokia 6500 slide buttons do not work, keypad buttons do not work accept the red 'off' button but make the noise when i press them. This happened after i restarted my phone after the battey had died
How i unlock my nokia 6500 slide ?
There are lot of ways to Unlock the Phone from Network lock,But i suggest the Network Unlock code to unlock the Phone from Network ,you can get the unlock code at here
Mobile-Unlocker and follow the instructions below and unlock it step by step.....
1 - Switch on your Nokia 6500 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Unlocking instructions for Nokia 6500 SLIDE:
Note :For Nokia 6500 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6500 SLIDE
Sep 07, 2011 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide 0,*,# buttons r not working so plz give me solution.
my friend,
in that case, ur phone has a keypad malfunction... in most cases the history of a phone is either water damage or drop off...
if u know how to dismantle your phone check the keypad membrane see if it is corroded or not... test it using a tester whether it has a supply... check also the flex.. maybe it has a damage.... check also the keypad crystal ic......
Apr 02, 2011 | Nokia 6500 Slide Cellular Phone
My security code is miss plz help me my phone is nokia 6500 slide
first switch off the mobile then press * 3 calling button and then press on off switch your handset will be formated
Jan 29, 2011 | Nokia 6500 Slide Cellular Phone
My Nokia 6500 slide buttons don't work. The only button that does work is the one that shuts down the phone
that the affects of your keypad ic has gone. then you have to change your keypad ic. thanks
Oct 26, 2010 | Nokia 6500 Slide Cellular Phone
Sometime keypad works and sometime dont work
Open the keypad. And clear the bottom of buttons (like coins) with office elastic eraser.
Aug 14, 2010 | Nokia 6500 Slide Cellular Phone
Call button does not always work straight away,
yes this is the problem that exists nokia slide phones.. ti had the same problem .. when i gave to nokia service center. they set the keypad and gave it.. but it started malfunctioning in few days.. my suggestion is not to waste money in fixing it.just use the left button and press answer to attend and make calls...
Apr 07, 2010 | Nokia 6500 Slide Cellular Phone
I own the nokia 6500 slide. The phone got wet. The start up button is working and then I dial my password but the main button that you push to accept the code is not working. Is there any other way to...
On your case, you will need a live technicians to do the work for you. The unit keypad need to clean and swiped out for any residue of water on it's keypad. It is better not to use or turn the unit ON until it was not attend and clean as I said, to avoid any further damaged on the unit like any short circuit on other parts, that can result for bigger problem.
The unit only need to be clean and dried out for any residue lives on the board.
Hope this initial information and idea helps, advised me here again for any clarification.
micro~
Feb 23, 2010 | Nokia 6500 Slide Cellular Phone
All buttons suddenlly stopped work correctly.
must be check if it exposed to any sort of liquid and if not remove the memory card and try to do software
May 11, 2009 | Nokia 6500 Slide Cellular Phone
All the keys Stopped working
What you probably have is a bad keypad. That explains why some keys are not working. Replacing the keypad is the only way to fix this.
Apr 22, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500 slide keypads sometimes won't work
Mine does the same. A technician has advised me it's a flexi error.Yet if you want, you can do what I usually do lol...Slide your thumb progressively over button 3,then 2, then 1, then 4, then 7, down to *. Do this continuously and it should work after a few tries.
Feb 07, 2009 | Nokia 6500 Slide Cellular Phone
Cell Phones Logo
267 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
