Question about ASUS A8N-E Motherboard
Memory slots DiMM A1&A2 does not work
I have changed the processor in A8N-E mo-bo (AMD Athlon 3000+ --> AMD Athlon 4200 X2). Unfortunately one of the new processor's pins was deformed and after the removal was broken...
I put the old 3000+ processor into the mo-bo.
When I put a memory stick in A slot (A1 or A2) on start the monitor is dark, and beeep ----- beeep ----- beeep emitted.
This sticks (2 Kingston 512 Mb PC3200) works fine in B slot.
Before my action the sticks were in A1 & B1 slots and the config was perfect (3 years ago).
  • g_lensi Jan 08, 2008
    I have already tried it.
    When only one stick is the A slots (A1 or A2) the mo-bo don't work (beeep...beeep...).
    The same stick operates well in slots B (B1 or B2).
    Is the memory controller of the processor damaged? Or the mo-bo?
    (I have cleaned the slots and the sticks.)
    Probably the processor is correct, with an another processor the symtom is the same.
  • 1,226 Answers
Fixed the memory well and and insert the memory one by one.
first insert 1 memory and test, and then so on.
If not work work clean the slot and also the memory.
Posted on Jan 08, 2008
  • Emelio Navaja
    Emelio Navaja Jan 08, 2008
    We can diagnose well if we let try your memory to some other computer. or we know or the physical damage of the memory is visible. Very rare cases that all the memory slot in the main board were damage except when the main board is physically dead.. I know that your main board is working properly by making a beeps means that main board did not detect any memory inserted on the slot. If you don't mind try another memory or if your are memory is good refer to your mainboard about the compatibility of the processor.
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at:
Jan 12, 2013 | Acer Aspire Computers & Internet
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Cpu Models to upgrade Compaq Presario sr1920nx
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
AMD 780G Chipset + DDR21066 Kit. Are they a match made in heaven?
You can populate half of your DIMM slots with DDR2 1066 RAM modules with this board. There is a limitation of the AMD AM2+ systems that puts a single-channel limit on the memory (hence the empty slots when using 1066).
Jul 11, 2009 | Gigabyte Computers & Internet
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
ASUS A8N-E Motherboard Logo
374 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
