Question about Microsoft Xbox 360 Console
My xbox 360, had the E74 error problem, with 1 red light! I fixed that, but now it starts up as a working xbox but when i put a game in it wont play it, and just says play Dvd, can u help Please!
    Guru:
  • 212 Answers
Hello rickster32
As you have mentioned that you got a E74 error problem which you got fixed up, E74 problem is a hardware related issue so the problem you are now facing is linked to a messed up dvd rom firmware issue.
It is very much possible that post you have fixed E74 problem your dvd-rom firmware could have gone corrupt and now is not recognizing the game discs and only playing dvd's
It would be advisable to send your unit to MS support if in case it is under warranty
Posted on Nov 18, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
Red light blinking system error E74
this might be a hardware failure. try turning it off then back, or try keeping a fan on it when you play on and if that doesn't work call 1800myxbox there you'll find step by step instructions to send it down to texas and get it fixed. if that happens three times you will recieve a brand new xbox 360 that has that problem fixed. also keep in mind to keep your hard drive before you send it to be fixed. i really hope this helps with your problem
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
1 red light
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
E 74
Heres the problem
Section 4 is flashing red
- Hardware Failure
Specifically
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known
to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected
directly to the AV cable) in rare cases it is the GPU.
If changing the cable doesnt work then you will need to get it fixed by Microsoft
Check the documentation that came with your Xbox 360 for contact information.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Aug 24, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
1 red light turns on when going to play it
The cause of E-74 with one red light Error might be overheating of your console and foravoiding such error in future you need to put your machine at an openspace. Ensure that it is placed near the window or you can also makesome external arrangement for cooling of console such as cooling themachine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Eitheryou can send your Xbox to Microsoft (Please note that microsoft is nolonger providing extended warranty for E74 with one red lightError) and wait for 3-4weeks. If you don't want to wait for a month, you can also fix E74 with one red lightproblem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Jun 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
89 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
