Where can I purchase a LKA-CR15C card reader for my XION COMPUTER? mine will no longer read from the SD/MMC port. Gordon
  • yadayada
    yadayada May 11, 2010
    we are not a parts service, please chech wioth best buy.
  • 478 Answers
Here is the Information that you needed to find your reader writer
Posted on Dec 09, 2009
Targus High speed SD/SDHC/MMC Micro SD-TF Card reader could read any of the SD/SDHC/MMC cards earlier when I had purchased it on my Lenovo Think Pad laptop having Window-7 . Now it is showing, when in
This is more likely a problem with the card. If the partition tables corrupt then Windows will see the card but won't be able to read data on the card. You will need to format the card.
Jan 30, 2013 | Electronics - Others
Tip
You can purchase a Targus card reader from Walmart which will plug into a USB...
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site:
To operate plug card reader into the USB port, go into "My Computer", click "Removeable disk drive", insert your memory card into the card slot and upload your data. Please remove your memory card before disconnecting the card reader.
on Dec 13, 2009 | Saws
Tip
Downloading picuters directly from your digital camera SD or XD card.
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site: To operate plug card reader into
on Dec 04, 2009 | Cameras
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
Will a Compaq Presario SR1820NX read SDHC memory cards?
Dear Artressfam,
Compaq Presario read all types of SD and MMC Cards,but all you need to do is connect your card to any USB card reader then insert USB card reader to on board USB port(Behind the Computer).
I think it helps.
Chandrashekhar
Dec 27, 2010 | Computers & Internet
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
Looking for usb cable for technika sh-1060 have been in touch with tesco to no avail! thanx, ros
http://www.memoryforless.co.uk/store/erol.html#21423X0
Cable Not available for this camera - Have you considered reading SD/MMC with a USB Reader ?
This device will allow you to read your SD/MMC removed from your camera directly through a USB port on any PC.
It connects directly to any USB port, meaning your images and card can be read quickly and easily direct to your hard drive from windows explorer.
If you need any assistance please contact us directly.
SD/MMC Reader / Writers
If you dont like the above solution and find somewhere that does sell this USB cable...Let me know!! I need one too!
treacs@live.com
Oct 04, 2009 | Cameras
Have a aspire 5735 laptop need to know how to insert sd compact flash disk
If your laptop does not have a built-in memory card reader then purchase an USB multi memory card reader that can read a variety of memory cards such as SM/XD, SD/MMC and CF/Micro drives memory cards.
All you need to do is plug in the memory card into the card reader and then plug the card reader into the computer's USB port. The computer will see the memory card as an external memory device.
Aug 03, 2009 | Aspire Computers & Internet
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Problem with memory stick micro m2
is the card being read on the other device like camera/mobile etc.
if yes than card is okay
its the pc which is not compatible with your card. in this case u cannot do much but buy a card reader costing 5 usd
Apr 27, 2008 | SanDisk Memory Media
Computers & Internet Logo
David Payne
David Payne
