Question about Sony Cyber-shot DSC-S600 Digital Camera
Camera will not switch on - Sony Cyber-shot DSC-S600 Digital Camera
Canon 450d lcd will not turn on at all, viewfinder says busy, and camera will not take pictures
In menu option C.Fn-12 you can choose to switch the display off (or on) when you switch on the camera. The display stays off even if you switch of and on the camera.
Press the button <DISP> and switch off the camera, while the settings for recording are on the screen. After you switch on the camera, the LCD screen will be switched on again.
Please refer toy your english manual, I had to translate, because I don't have the English version.
Nov 20, 2013 | Canon EOS 450D Digital Camera
Once camera switch off lens retracted but camera not switch off the sreen display is on
Remove the batteries and press power and hold for 30 seconds, replace battery and power on.
Mar 16, 2012 | Nikon Coolpix 3700 Digital Camera
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Repost of A70 Mode Switch Problem
Make sure that the mode switch on the cover is in the playback position. Unfortunately, I don't have a source for new switches.
Apr 24, 2007 | Canon PowerShot A70 Digital Camera
Canon A70 stays in replay mode
Gerry, The mode switch is a very common problem that causes the camera to remain in either play or camera mode. The stem breaks off the top of the switch and no longer functions. If this is not the case, the flex harness (operations unit) can get torn on top if the camera has been dropped. If the switch appears to be good, check for ground switching between the two outer legs of the switch, the micro gets a low signal from the mode switch to determine what state the cameras in. Good luck, this is a nice camera! Joe Weibel Custom Electronics (customelectroncis.org)
Feb 13, 2007 | Canon PowerShot A70 Digital Camera
ON/OFF SWITCH
It sounds like a bad connection with batteries or battery holder or a loose cable somewhere within the camera. Maybe even a dry solder joint or intermittent fault with the power switch. Unless you know your way around the innards of your camera I'd recommend a qualified tech to take a look. BMW
Jun 27, 2006 | Kodak EasyShare DX7440 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
