Question about Panasonic KTR320 2-Way Radio
How does it work? do you just select a channel for both radios and talk? Panasonic KTR320 2-Way Radio?
  • 1,498 Answers
Hi Four,
Basically, yes.
Both devices must be on the same channel.
To talk, press the PTT (Push To Talk) button.
Test communication close up first.
If you get no response, double check the channel. I find they are easy switched by mistake on digital models like yours.
Best regards
Mike
Posted on Nov 12, 2009
What mode do cobra micro talk walkie talkies charge on
the ones I have charge on their own charging stand, they are great radios for the $$ as compared to others I have
Dec 27, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
I have a uniden GMR1448 Two-Way Radio. Both handsets work but they cannot talk to one another. They used to work fine. They are tuned to the right channel and I did everything that I find obvious, like sub...
Check whether the channel and the sub code are same?If this is not same it will not work.
Put the sub code to off.Follow the below steps
1.Press chan tone/scan in channel select mode.The subcode indicator will flash. 2. Press the UP arrow  or DOWN arrow key to increase or decrease the code number displayed.You can also select oF (OFF) at this stage. 3. Press chan tone/scan to exit the Menu.
Thank You
Nov 16, 2010 | Uniden GMR1448-2CK Two Way Radio
I can't get the 2 way radios on the same channel
Press the Menu button. The channel number will flash. Press the adjust keys to select the channel number. Press the menu key again and the Subchannel number will flash. Set to desired number. Then press the push-to-talk key to get out of menu mode. Repeat with second radio and be sure to choose the same channel and subchannel. Then adjust volumne as needed.
have fun!
Nov 19, 2009 | Midland LXT310 2-Way Radio
Repeater channels
Are you certain you are near a GMRS repeater in your area? If you have your radios set for the GMRS repeater channels the radios will not talk to one another unless you are in close proximity of a GMRS repeater. To talk radio-to-radio you would need to set your radio to one of the simplex frequencies available in the radio.
If you know you are close to a GMRS repeater, you might double check the Tx and Rx frequencies of the repeater to be certain they match the settings in your radio. Also, you will need to be certain your interference code is set to zero (the off position) to be used with the repeater. I didn't read up on the T7200, but if it has a Qt filter, set it to zero also.
Jul 26, 2009 | Motorola Talkabout T7200 (22 Channels)...
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
No chann. 70 on Uniden 525 marine radio
You can't "select" channel 70, nor can you talk on channel 70. Channel 70 is reserved for the exchange of digital data between radios.
And it is not possible to address an "emergency" (do you mean distress? or urgency?) message to an individual recipient.
Your radio is not allowing you to do any of these things because it has been (correctly) programmed to discourage you from doing things that would be illegal.
If you set up a routine call with your friend (or anyone else), you should find that once the two radios have completed their (almost instantaneous) exchange on Channel 70, they will both switch to whichever working channel you had selected, and he will get a beeping sound to tell him that there is an incoming call.
Sounds to me like both radios are doing exactly what they are supposed to.
May 17, 2009 | Uniden Boating
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Panasonic KTR320 2-Way Radio Logo
82 people viewed this question
Top Panasonic Radio Communications Experts
Jason
Lawrence Oravetz
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
