Question about Hyundai ImageQuest L70S 17" LCD Monitor
It will not turn on, and all power is connected
    Scholar:
  • 75 Answers
Check the video cable.
Posted on Nov 12, 2009
Loss of power when printing
  1. Is the printer off?
    Press the I on the power switch to turn the printer on.
  2. Is the power cord loose or disconnected?Turn the printer off and connect the power cord properly. Turn the printer on again.
  3. Is the printer connected to a correctly rated outlet/socket?Connect the printer to an AC power outlet/socket that you know works. Do not connect any other equipment to the outlet/socket. Do not connect the printer to an auxiliary power outlet on the back of a computer.
  4. Is the printer defective?Turn the printer off immediately, disconnect the power cord from the outlet/socket, and contact your dealer or Brother Customer Service.
    Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
Playstation 3 has power but nuthing coming on tv
depends on wether your connecting ps3 to standard which is rca jack connecters or hd,,hdmi,,if it has been connected hd before and ur connecting standard ,,thats why,,either way,,connect however you want turn on power,,hold power button down for a few seconds,,you may hear a beep,,,if not it may turn off ,,either way should have screen when it comes back on,,if still nothing,,turn it on,,hold power down till cuts off ,,turn on again hold power,,u will here a beep,,keep holdind,,next,,it will be ,,2 beeps reliese,,right then,,a screen will pop up,,,connect usb to controller and restart ,,good to go,,good luck
Feb 09, 2013 | Sony Playstation 3 (PS3) Console
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Code 803
E803 (The output voltage of the composite power PCB has a fault.) Cause Wiring Composite power supply PCB (J208) Continuity DC controller PCB Composite power supply PCB
• If it does not turn on, see "The scanning lamp fails to turn on." • If it turns on but is dark, replace it (its ends may be blackened). Correct the connection. Connect it securely. Replace the harness. Replace the DC controller PCB. Replace the composite power supply PCB.
Turn off and then on the main power. Is the problem corrected? Does the scanning lamp turn on when the Copy Start key is pressed? Or, is it dark after it has turned on. Is the connection between J111 on the DC controller PCB and J204 on the composite power PCB good? Is the connection of the connector J208 on the composite power supply PCB normal? Check the 24-VDC line between J111 and J204. Is its continuity good? Is there an output of 24 VDC at the J111-1 and J111-3 on the DC controller PCB
Mar 16, 2010 | Canon imageRUNNER 400S Copier
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset power
1.Unplug the power cable and turn off the the unit.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
To do full Reset.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Ultra X3 800 watt power supply
yes PWR SPLY must be connected to MB and MB must be grounded when bench testing. thats the quickest easiest way to check..
Jan 07, 2008 | Thermaltake W0133RU ToughPower 1200W...
Hyundai ImageQuest L70S 17" LCD Monitor Logo
153 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
