Question about Frigidaire FEF366 Electric Kitchen Range
Electrolux glass top on our 4 ring hob has
Our Electrolux EOB5610X glass top on our 4 ring hob has smashed, i need to replace it where would i get a new one, and is it an eassy process,
Thanks in advance,
Richard
    President:
  • 1,865 Answers
Error code e9 on hob aeg hk85440075
From another Post from Daniel T:
E9 on this hob means a user interface control board fault. This is the touch control board which you press to turn on.
What the service manual says is disconnect the hob from the mains connection and leave for 60 seconds. Then wire it back up and turn back on and see what happens.
If still the same then the user control board needs to be replaced.
To access this you need to remove the hob from the work top and remove the screws holding the glass on all 4 sides of the hob.
Then you can lift the glass top off.
From there you will see the user board in the front its the smaller board.
Replace this and that should cure the fault here.
If you need anymore info just get back to me.
My Zanussi induction hob flashes an error code E9 when try
Oct 30, 2015 | AEG Washing Machines
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Looking to replace a broken glass covertop for a Magnetic Induction hob
I looked up your cooktop and discovered it to be made by Frigidaire.
Hence & therefore, try the website "searspartsdirect" and see of they will give you schematics to buy the parts for your needs.
God bless your efforts.
Mar 06, 2018 | Sunpentown Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
Mar 01, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Frigidaire FEF366 Electric Kitchen Range Logo
41 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
