Question about Lexmark T642 Laser Printer
I keep getting the message Service Printer Head--what can be done
  • 231 Answers
This means you have a faulty laser scanner
It will need a technician to replace it
Posted on Dec 07, 2009
I have a canon ipf700 and power went off and now the machine is coming up with an error message of E161-403E. any help will be great
Hold down the roll/media button and the info button while turning on. Wait about 10 seconds and release roll/info buttons. You should get an "S" in the upper right corner; this puts you in service mode.
Push menu then scroll down to maintenance then right arrow to head replacement. Then get out of service mode turn off.
E161 403E means abnormal print head temperature. The print head needs to be replaced. Boot printer into service mode, and from the menu select head replacement.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 03, 2011 | Canon iPF700 InkJet Printer
C6380 hp printer displays message: ink system failure Oxc19a0022 I have reset the system and then cleaned the printhead but the message persists
Try resetting the printer a second time. If you have done this step, unfortunately, you either need a replacement print head or the printer needs service.
Print heads are not returnable if a new one doesn't solve the problem.
You can order a replacement print head either by phone or by entering your printer's model and serial numbers here: http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=7E679E4B5EF640FF85D318BA520F8C9A .
I wish that I had better news.
Mar 22, 2011 | HP Photosmart C6180 All-In-One InkJet...
I've had my Lexmark x2580 installed on my new Acer Windows 7 machine for 6 months now. I kept getting a "please register" message but since it is about 2 yrs old & I'd already registered, I...
Make sure your print spooler service is running. This article in the Lexmark website about How to Restart or Reset the Print Spooler in Windows might help you enable the service again. If problem continues, please contact Lexmark technical support for additional assistance.
Feb 10, 2011 | Lexmark X2500 All-In-One Printer
Replaced black ink but still says no black ink
please ignore that message and keep on printing, and if your printer does not print then dont use your printer for several days and keep your cartridge out of your printer for around a week and a half,but keep it safely so that its printing head is not damaged. and run the printer without cartridge for several times . this will help the printer in identifying that there is no cartridge in the printer and after that keep the cartridge safely out of printer and run after 10 days again by putting back your cartridge
that may help you, and after this procedure the problem which you can face is of dry ink .so apply some isopropyle alcohol on your cartridge print head (don't rub it)only put some drops of it on head and let the print head absorb it, this may be done when your cartridge s identified by your printer after 10 days and the error of low ink is gone.
Best of luck
Take care and please vote for me
Sachin
Jan 25, 2011 | HP OfficeJet Pro k550 Printer
I keep getting message "Clean right print head". Can it be done here or do I need service
Windows XP or Vista
1. Go the control panel and select Printers
2. Choose the applicable printer, right click and choose properties.
3. Click on the tab or button that says "maintenance", "cleaning" or similar.
4. Select which nozzles to clean (only applicable for some printers)
4. Run the program, do NOT perform any other operations until the cleaning process has ended.
5. Print a test page, repeat the process 2-3 times if no visible results are shown.
Oct 10, 2010 | Canon imagePROGRAF iPF8000 Printer
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Print head problem( no ink getting to head)
Hurl,
Did you ever find a solution to this problem....it seems like the EXACT same problem I have with this same printer......PLEASE HELPPPPPP!!!!!!!
publisher@hawaiisoccermag.com
Jul 24, 2007 | Canon imagePROGRAF W6200 InkJet Printer
Lexmark T642 Laser Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
