Question about Canon ES50 8mm Camcorder
No video playback
When I turn power knob to play, the power flashes on and off four or five times before remaining on and when play is pressed there is no picture only sound. sometimes there is snow, other times lines ranging in color, sometimes no picture at all. every once in a while there will be a picture. record still works for video and sound. any ideas how to fix this?
    Scholar:
  • 62 Answers
Sounds like a classical video head problem. May be quite expensive to fix. Of course you can first try spraying the head with a "no residue" contact cleaner and then dry it out with pressured air to see if that fixes the problem.
Posted on Aug 21, 2008
How to make a digital copy
o do this:
Press the power switch. (Capture mode)
Press the Play button. (Playback mode)
Press the four-way controller (down). (Playback mode palette)
Press the four-way controller (right) 3 times to select [Image/Sound Copy].
Press the OK button to display the screen for selecting the copy destination.
Press the OK button to copy the data.
Press the Play button or press the shutter release button down halfway to return to Capture mode.
Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
Jun 11, 2012 | Sylvania Hd1z Sdsdhcmmc 720p Hd Pocket...
How do i program my remote
Things You'll Need:
  • RCA Universal Remote Control
  1. 1 Turn on the component you want to program.
  2. 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  3. 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  4. 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  5. 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  6. 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  7. 7 Press and release the STOP button to save the new code.
Tips & Warnings
  • Each time you press the PLAY button in Step 5, the ON-OFF button blinks ten times and a list of 10 codes is sent to your component. This process continues until all of the code lists have been searched. If the component has not turned off after all codes have been searched, the ON-OFF button blinks four times, turns off, and the Auto Code Search is exited.
  • If you do not press the STOP button at the end, the new code will not be saved.
Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1CzcjxWJw
Feb 04, 2011 | RCA Universal Remote Control
How do I enter the code for my 2006 Honda Accord LX? I press the preset 1 and 6 keys simultaneously, but it continues to display the letters C, O,D, E individually when I try to input the code.
Use the preset buttons to enter the five-digit code (I assume that you have that; if not, see below). When it is entered correctly, the radio will start playing.
If your vehicle is equipped with a navigation system, press and release the TUNE knob; the number ‘‘0’’ appears on the display.
If ‘‘0’’ is the first digit in your code, press and release the TUNE knob to store it.
If ‘‘0’’ is not the first digit in your code, turn the TUNE knob left or right until the first digit is displayed.
Press and release the TUNE knob to store it. Enter the remaining digits the same way.
If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code. If you are unsuccessful in 10 attempts, you must then leave the system on for 1 hour before trying again.
If you don’t have the code, a dealer can access your code with your radio’s serial number. To access the serial number, turn the radio on. It must display ‘‘CODE’’, then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.
Hope this helps you.
Nov 09, 2009 | 2006 Honda Accord
Code Search
First try this method as it is the quickest way,
To program a component using the Automatic Code Search method, perform the following steps:
1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button.
aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Only use the codes below if the auto code search dosen't work. Codes program a zenith tv are below
Zenith 1000, 1001, 1004, 1051, 1083, 1151, 1152,
1154, 1217
You can click the link below you will be able download the manual.
http://support.rcaaccessories.com/main.html?topicid=216&Referring%20DeviceDocID%20List%20Index=1&navtypeid=16&pagetypeid=35&prevPageIndex=13&selectedmodel=RCR450&selectedFamily=generic
Mar 15, 2008 | RCA RCR450 Remote Control
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Remote code for my ge universal remote
This is the quickest and easiest way to program your remote: To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Copy of manual below as well
http://support.rcaaccessories.com/doc/Device_Documents/manuals/RCR450_manual.pdf?deviceDocId=216&docid=959&docid=983&navtypeid=6&pagetypeid=7&prevPageIndex=31&selectedmodel=RCR450&selectedFamily=generic&nvty=m
Oct 26, 2007 | RCA RCR450 Remote Control
JVC-GR-D371U
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon Gl2
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Canon ES50 8mm Camcorder Logo
137 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
