Question about Compaq Keyboard
Back space key seems to stick in the on position (electronically not physically)when pressed and released. If the key pad is removed and the backspace pressed with a pen it seems to work normally.
  • 748 Answers
If it's only the backspace that misbehaves, there might be some contamination beneath the key, causing a "mild" short when pressed (some liquid for example). If you are savvy enough you can try and disassemble the keyboard and clean it. Tip - if you attempt to dismantle the keyboard and remove the keys, make a photo, scan or xerox copy of the key layout to know how to put them back together :)
Posted on Nov 12, 2009
  • 72 Answers
That happens when the spring/switch of the specific key go bad, normally in such cases the entire keypad have to be changed but if you are lucky then it is possible that only one key will be changed.... so without wasting time get it repaired from some professional
3 keys on my Optima lagtop suddenly stopped working
There is an electronic contact just under where you cleaned with damp qtip, so that may not have been very wise! There are screws on the back side of your laptop that do not remove but do loosen and release the keyboard. release the keyboard and gentely get keyboard to pop up and reseat connection. normally on laptops, keyboardsare able to lift where the f keys are and then slide in the direction of space bar to f keys
Jan 30, 2013 | Optima Centrino Traveler 680009100095...
Xerox memorywriter 6020's space bar sticks
Under each key there is a contact pad, they get old and the foam falls apart. They can be fairly easily replkaced the pads are 1.50 apiece.
Befor you do anything realize that the ribbons are no longer made.
DickyO
Jan 16, 2013 | Office Equipment & Supplies
The A key keeps sticking on my Acer Aspire 5551- help!
If you mean the key is physically sticking, as in pressing down but not releasing,it is possible that the plastic spring or rubber stop under the key has broken.
You can remove the key cover and check if the plastic spring that the key attaches to is moveable and that the small rubber stop underneath is present. If the spring is broken, a replacement key can be got from ebay for a small cost. Check also that there is no dirt or sticky patches under the key, these should be removed using meths or a similar solvent.
If the key is not physically damaged, or there is no dirt etc underneath, there may be a problem with one of the traces on the ribbon cable to the motherboard, this will necessitate a new keyboard
Jul 26, 2011 | Acer 91.63X07.001 Keyboard
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
My spacebar issticking.
Yup! you can do that.. carefully... i repeat, carefully pry-upward the space bar using a hard plastic card (I.D cards are best). Clean the hinge with a brush. Press down till you hear a click to return the key back to its position.
Mar 15, 2009 | Dell Latitude D600 Notebook
My son spilled soda on our keyboard.Now the x and s stick. I took it apart and cleaned it, but it still sticks. Also, a wire fell out from the space bar and I cannot figure out how to put it back.Thus the...
You cleaned the rubber under the buttons and the buttons too? All you do is put the metal bars straight down then angle it about 10 degree towards you then put it in like a regular key, but if you lost the wire then.... might need to get a new one, heh.
Dec 22, 2008 | Computers & Internet
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Margins
Most electronic typewriters work the same way to change margin settings. You use the space bar to move to the desired location then press the right margin key. You should hear a beep. If you need to set it farther to the right of the current position, then use the space bar to move the carrier to the current position, once it stops moving then press margin release then space to the new position then press right margin key.
Aug 10, 2008 | Brother EM-530 Typewriter
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
Nov 14, 2007 | Logitech Cordless Desktop MX3200 Laser...
Compaq Keyboard Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
