Tumbler not working
I have a Kenmore Series 70 dryer and the power and heating element are working but tumbler is not rotating.
  • 26 Answers
Please check to see if motor is okay or if the belt broke.
Posted on Nov 12, 2009
Kenmore 70 Dryer won't heat
Hi Jason
There is no fuse to replace only thermostats/thermistors...and heating element.
Here is some things to check:
Apr 25, 2013 | Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
I have a kenmore 70 series dryer that overheats in evrery cycle even in the air dry cycle. Another problem is that when the cycle is done the tumbler cuts off but the timer keeps running keeping the...
Sounds like you may have two problems but the main problem might be that the element may be broken and one side is grounded, The switch on the motor may also be stuck in the on position as well.
Feb 26, 2011 | Kenmore 62802 Electric Dryer
Kenmore series 70 dryer will not heat up replaced heating element thermostats check ok with ohm meter
If heating element was replaced and still no heat, Then what I would do is test the voltage current in the wiring and see if there is actually power to the element.
All parts to make dryer heat are:
heating element
thermal fuse
thermostat
timer
any one of these units can be faulty
Oct 10, 2009 | Kenmore Dryers
Where do I find the heating element in a Kenmore 70 series dryer model 110.96575100
the part number you will need is 279838 and you can get that at whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Dryers
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Kenmore 90 series
possible burned out heat element
Jan 25, 2009 | Kenmore 73932 Gas Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
