Question about Sherwood RX-4105 Receiver
Power cuts off after 2 seconds after stereo start button is pressed
    Problem Solver:
  • 7 Answers
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Posted on Jan 11, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sherwood Master
  • 1,001 Answers
Wireless CSR4.0 Portable Bluetooth Receiver Wireless Hands Free Calling for Home 3.5mm Audio Out Music Streaming Sound https://www.amazon.com/Charm-Wireless-Bluetooth-Streaming-System%EF%BC%88Black%EF%BC%89/dp/B01G827XGM/ref=sr_1_9?ie=UTF8&qid=1484619390&sr=8-9&keywords=Charm+sonic
Posted on Jan 17, 2017
Forno sy36x oven.. following powercut, timer wont set, therefore oven wont come on. digits constantly flashing
after a power cut, the clock display will-automatically reset to 0:00 and begin to blink.
starting buttons left to rigth Press the
2nd and 3rd buttons simultaneously, release,
and then set the exact time (within 4 seconds) using
the +buttons.
advances the hours.
The button
- decreases the hours.
The time can also be changed in a second ways
1.Repeat all of the steps above.
2.Press the 4th
button, release, and then use the +and -
buttons to update the time.
Sep 23, 2014 | Ovens
I have a 2008 ford ranger xlt 4x4 4.0 truck. we changed the motor and sense the battery was disconnected the anti theft system locked down how do we unlock it.
follow this steps and fix it. God bless you
Turn the vehicle on. The engine does not need to be running but the ignition should be on to power the stereo.
  • 2 Press the "Source" or "Power" button to turn the unit off.
  • Sponsored Links
  • 3
    Press and hold down the "Minute" button (located to the left of the GM vehicle stereo's display. Some models require pressing and holding the left arrow button if no "Minute" button is present.) Release the button once the display shows "0000."
  • 4
    Press the "Minute" button (or left arrow) to set the value of the third and fourth digits of the anti-theft code. Release the button once the proper value for the last two digits is displayed.
  • 5
    Press the "Hour" button (or right arrow button) to set the first and second digits of the code. Release the button once the four-digit code is accurately displayed.
  • 6
    Press the "Mode" button to lock in the code you set. Turn the stereo deck on by pressing the "Source" or "Power" button to complete the reset.
  • Read more: http://www.ehow.com/how_6924001_reset-anti_theft-code-car-stereo.html#ixzz2gZHpH2aT
    Oct 02, 2013 | 2001 Ford Ranger Regular Cab
    How to change clock on Pioneer cxc5719 car radio?
    1 Turn the ignition key to On or Accessory. Pull up the emergency brake. 2 Press Source or Power to turn the Pioneer car stereo off. 3 Press the Clock button to display the time. 4 Press and hold the Function or Audio button for 3-4 seconds. The display will come on, and the hour should flash. 5 Use the Up or Down buttons to change the hour setting on the stereo. 6 Press the Left or Right keys to get to the minutes. When the minutes start to flash, press the Up or Down keys to set the clock to the correct minutes. 7 Press the Function or Audio button again to exit.
    Mar 25, 2011 | Car Audio & Video
    How do I reset my yamaha receiver htr5730
    http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
    Page 52
    1 Hold down STEREO on the Front Panel
    "Factory Preset" appears on the front panel
    2 Press STEREO to select the desired setting.
    'Reset' To reset to factory presets
    'Cancel' to cancel without making changes
    3 Press STANDBY/ON to confirm your selection
    Jan 15, 2011 | Yamaha HTR-5730 Receiver
    I have hooked up all the wires in the appropriate color-coded order and my stereo has no reception. It has power but no reception. The antenna is hooked up also. It is a Kenwood KDC 119 and the vehicle...
    Selecting the station. 1 Select tuner source Press the [SRC] button. Select the "TUnE" display. 2 Select the band Press the [FM] or [AM] button. Each time the [FM] button is pressed it switches between the FM1, FM2, and FM3 bands. 3 Tune up or down band Press the [4] or [¢] button. During reception of stereo stations the "ST" indicator is ON. 1 Select the band Press the [FM] or [AM] button. 2 Select the frequency to put in the memory Press the [4] or [¢] button. 3 Put the frequency in the memory Press the [#1] - [#6] button for at least 2 seconds. The preset number display blinks 1 time. On each band, 1 station can be put in the memory on each [#1] - [#6] button.
    Nov 03, 2010 | Car Audio & Video
    Display for radio stuck in '7 SAFE' mode
    This sounds like a Phillips Car Stereo:
    To get the code in:
    1. Turn the stereo off.
    2. Turn off the ignition
    3. Turn the ignition back on (dash warning lights on)
    4. Hold and keep down the AS button on the stereo.
    5. Turn the stereo on.
    6. Release the AS button after 4 dashes appear on the display
    7. Now enter code (if code = 7009. Press preset button 1 seven times, button
    2 once
    3 once
    4 nine times
    If you go past you can go round again by pressing the
    preset button repeatedly
    8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
    9. The stereo after beeping will scan to program channels
    You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
    Time delays work as follows:
    Attempt 1. 10 seconds
    Attemp 2. 30 seconds.
    Attempt 3. 10 minutes.
    Attempt 4. 20 minutes
    Attempt 5. 40 minutes
    Attempt 6. 80 minutes
    Attempt 7 160 minutes
    Attempt 8 320 minutes
    Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
    Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
    So, be prepared for a VERY long wait to be able to enter the code!
    Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
    May 09, 2009 | Car Audio & Video
    DYSON washine machine fault
    To Clear F11 Code after a power cut.
    1, Power off at the machine. Do the next 4 steps within 3 seconds.
    2, Press Temperature Button in.
    3, Power on
    4, Release temperature button
    5, press Soil Type button
    Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
    Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
    Overall Problem - Panasonic RX-ED707 won't work properly at all
    only 1 reason for that faults :
    there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
    so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
    it happened to me also and that works perfectly
    good luck
    Nov 14, 2007 | Panasonic RX-ED707 Boombox
    Kenwood KDC-MP825 car stereo problem
    My wife experienced the same problem this month, December 2008, after owning the KDC-MP825 for 3.5 years (what's up with that?). It would power on briefly, the panel would move, then after 2 seconds it would shut down. After 15 seconds, it would power again, panel motors whir, then shut down. It would keep doing that while the key is in ignition.
    This appeared to have solved the problem:
    Hold down BUTTON [5], press the RESET button (you'll need a ballpen to press between the AUTO and SCRL button).
    This was the procedure for getting the receiver out of demonstration mode. Maybe the cold weather here in New Jersey placed the unit into demo mode?
    Aug 20, 2007 | Kenwood KDC-MPV8025 CD Player
    Sherwood RX-4105 Receiver Logo
    845 people viewed this question
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Josh Whitehead
    Josh Whitehead
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
