Question about Sony Televison & Video
Gray bars on both sides of the screen! Sony Bravia KDL-32L4000
I have a Sony Bravia KDL-32L4000 37 inch 10 months old. We had a regular DirectTV connection. Worked fine. We upgraded to DVR with DirectTV & ever since then, there has been 2 inch thick vertical gray bars on both sides of the picture! When we use our HDMI DVD player the bars aren't there, when we use our PS2 OR PS3 - the bars aren't there either! And yes, we did set our DirectTV to 16.9, so thats not it. DirectTV said that the DVR isnt a HD receiver, yet it has Buttons for 480i,480p,720p,1080i & resolution! My ps2 isnt hd,but there's no bars there!Im thinking I have to connect it a different way or something? I don't know, that's why I'm asking the Experts! Please help me out, before we break our TV,DVR,PS3 & every other electronic initialed thing I can find! :) Thank you!!!!
5 Suggested Answers
  • 8 Answers
SOURCE: Greater than 480i over component?
try switching the resolution settings on the DVD player and/or the TV. I have had a similar problem and there was a manual switch i missed.
Posted on Sep 16, 2007
  • 306 Answers
SOURCE: Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Posted on Nov 13, 2007
Will Direct tv recievers work with my new 23" widescreen ACER monitor? The monitor has VGA input,DVID withHDCP input and HDMI input
Posted on Mar 02, 2009
Big Hev
  • 64 Answers
SOURCE: PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
Posted on May 23, 2009
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
My Sony Bravia 40 inch TV is just over one year old. When switched on, the right side of the screen is covered by a dark cloud like distortion the other side is OK. After bout 10 minutes the screen...
The T-con board,the board that sit right at the bottom right in the middle of the center LCD panel.That board is dying.Tries websites like, to buy a refurbish T-con board for the replacement.
May 27, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Good day, I am all of the sudden getting double vision and a white line across the screen, it eventually goes away, not sure if it may be my directtv reciver?
This is a common problem for Sony BRAVIA KDL-52W4100. You can reconnect the LVDS cable to the Main board, the location # is CN4701.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia KDL-40v3000
Dec 21, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Open Questions:
Televison & Video Logo
542 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
