Question about Konica Minolta bizhub 350 All-In-One Laser Printer
IT KEEPS DISPLAYING ERRO C3452 ONLY. THAT ERROR IS DETECTED BY THE MACHINE I SHOULD PLS CONTACT MY TECHNICIAN.
  • Konica Minolta Expert
  • 158 Answers
This is a low fuser temerature code you can reset it by the following method:
1. on the right side of the machine there is a small cover you can remove next to the network card it just clips on pull down on the small lever and pull it down
2. once the cover is removed you will see a connector and a small hole with a switch in it to the right of the connector push the switch with a small object like a ball point pen.
3.when a small dot appears on the touchscreen hit the number 3 on the number pad.
4.enter the 8 digit service code which is 00000000 and touch end.
5. select trouble reset to reset the error code.
if the error code reccurs you will need to replace the fuser unit but i have seen the machines show this error when they are turned on while the room temp is cold first thing in the morning.
Posted on Nov 13, 2009
Testimonial: "very very helpful and timely. i will register with u"
    ???? ??????? Oct 31, 2013
    thank you very mach
    Problem Solver:
  • 3 Answers
While powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Posted on Aug 25, 2011
Bizhub 200 erro code c3452
Its related to Fuser Unit,
Try to reset by Switch On Main Power switch by holding Utility Button for 10-15 second.
Troublereset Option will appear
touch it
switch off again and on in normal way.
Dec 29, 2016 | Konica Minolta bizhub 200 Printer
What does erroe code f34
F34 is a motor error
and can mean many things from a blasted contact not so good
or brushes or a bad motor detect on the pump
Aug 05, 2014 | Siemens Washing Machines
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 has error code c3452
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code c 3452 on ineo 250+
develop ineo 250 machine error comes c3452
how i solve this
Nov 21, 2010 | Konica Minolta Office Equipment & Supplies
My machine keeps flashing f and h and keeps stopping mid cycle......help!
Hi
FH error indicates no water detected entering the machine or pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You'll need to Press PAUSE/CANCEL twice to clear the display. Please post a comment if you need more help.
Thanks
Rylee
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Erroe f11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the pre-wash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service technician.
Sep 01, 2009 | Kenmore Washing Machines
Erro code f23-1
If its F2- 31 , its the drum mark problem.The drum may be defective or the wrong drum fixed on a machine.Also clean the drum mark sensor on the drum unit.
Jul 30, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,508 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
