Question about GE Refrigerators
Frig has water dripping from freezer door
In the freezer compartment there is ice forming in from a vent in the back and then there is water dripping from freezer door
  • 2,237 Answers
The coils are frozen up from condensation due to leaky door seals and/or a plugged drain. turn it off, defrost it with a hair dryer, check the seals and the drain (under the coils), and turn it back on.
Posted on Nov 12, 2009
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water weeping out vents in lower back of freezer compartment
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water from the freezer falling in fridge
Usually this is a Door seal problem or a blockage between the frig and freezer compartment. There is usually a Tube that allows water from the defrost cycle to drain down to the pan beneath your unit. If there is ice, food particles, etc blocking that will cause water to enter the frig causing the mess. Listen for a fan to be running inside the freezer....if you hear none, than this may be causing the ice buildup that melts when the unit goes into defrost. If you unplug the unit, take the back panel off inside your freezer you will see coils and the ice. Leave unit unplugged to defrost the freezer and drain tube.....It should work normally when you plug it back in. If not, then you have a defrost heater or thermostat, or control board problem that needs to be checked by a technician.
Nov 29, 2008 | Whirlpool Refrigerators
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice forming on bottom of freezer
Switch off the power
First keep all the items out
Open the door and remove all the fixers
let the whole body will be get dry
check the freezer is there any gap between the door
Let me know if your problem is solved and rate me as FIXYA!
Mar 07, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
