Question about AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
  • 3,289 Answers
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Posted on Nov 12, 2009
I got a powermate 17 gal it wont shut off not until the breaker trips can't get the air set right on
Find the pressure switch. Remove the cover and loosen the spring loaded nuts on-till the switch opens. Readjust for the pressure you need. Keep it below the amp rating on the motor to keep the breaker from tripping. (RLA or FLA).
Dec 14, 2013 | Hitachi EC12 Portable Electric 2hp Air...
GE Profile 24, 15 years old: Occasionally, it trips the house ground fault circuit interrupter (GFCI). Tripping happens about 5 seconds after plugging to mains. For a week the problem disappeared, now it...
The motor (compressor) is pulling too high amps on the startup ... this tripps the GFCI...
The compressor cap is going bad or the motor is going bad...replace the realy and cap first...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | Refrigerators
Breaker breaks
This unit may have an internal overload mounted on top of the compressor. You would have to get to the
compressor to find out and it maybe faulty. That may
explain why the compressor comes on later on, this
overload protects the compressor from getting hot.
When you trip the breaker and then reset it again only to see it trip again almost sounds like a direct short or loose wire. It could also mean that your
capacitor needs to be replaced or that you need a hard start kit and the unit needs a good cleaning.
Try just operating the fan and see if it trips the breaker, if it does then either the blower motor is bad
or it is still the capacitor.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
My well keeps breaking the circuit breaker, I have had three pressure switchs put in they last for a few weeks and then they start tripping. Last time if I moved the wires at the pressure switch the pump...
The motor for your well pump is going bad and it is pulling too much current on the start up ...this is burning up the pressure switches and is tripping your breaker..
It may be cheaper to replace the whole pump then to just replace the motor...
heatman101
Apr 22, 2010 | Flotec Corrosion Resistant Shallow Well...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
What size line should i run to a 60 gallon air tank 375 feet from electric box and keep it running correclty, i have 10 gauge now and it gives a few good starts then it trips the breaker switch. It is a...
you need to run this compressor on a cooker trip (ei:30 amp) it pulls far to much power for a house hold trip (ie:15 amp) even if close to a 13 amp plug, at 375 feet???? thats some loss in the wire, over 50%!!!!! if it trys to start on the low loop.s it pops your trips!! right? hook it up to your cooker trip, but its still a very long hick for your power to get to,,
ps,,,this compresor never come with a three pin plug on it did it? like 3.7 hp = 4000 watt's app at the plug!
you could try puting a bigger starter (cap) on the motor that will hold more amp's for starting up on
and it will give your motor a longer,,,kick start,,,
talk to your frendly sparky first! ("caps," can and will kill you, if you tuch a charged up one!!!! so dont play with them) hope this helps you out
Oct 19, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
Pressure switch does not shut off unit and the
make sure your plugged directly to an outlet. no extension chords
tighten pop off valve colar
check oil / might be over filled
Jul 14, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381 Logo
580 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
